Old 01-10-2003, 03:37 PM   #1
texnician01
texnician01's Avatar
windshield doesn't fit
the guy came to put in the windshield for my truck. he got it al in but the gasket puckers in the curves along the top. he said he thinks it's the glass that is not bent correctly so he's looking for another manufacturer and see if that fixes the problem. Anybody got any Ideas? the glass that he brought says lamishield.
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 01-10-2003, 03:42 PM   #2
zyggy72
Can't kick the addiction!
The glass may not be the problem. On my 72, I was supplied with the wrong style windshield rubber and the same thing happened as you described when the windshield was installed.
zyggy72 is offline   Reply With Quote
Old 01-10-2003, 03:53 PM   #3
Woody
How long has he been installing windshields? These are really tough to get in and seated like they should be. The windshield looks as if it has the wrong bend in it and the lower corners are a real B%tch to get right. Double check that the gasket is correct.
Woody is offline   Reply With Quote
Old 01-16-2003, 09:16 PM   #4
chiphayes
windshield
i think the installer is just not seasoned well,ibroke 2,and a friend who has done windshields for 20years broke 2,before we got it,and we had new rubber,they just arent easy,try warming the strip up very warm.
chiphayes is offline   Reply With Quote
Old 01-16-2003, 09:24 PM   #5
skyhawk1
skyhawk1's Avatar
I called a windshield place here in WV and they sent a guy out that had never done a windshield in one of our trucks. Needless to say, he broke it trying to put it in. After they order a new one the guy that owned the company came out and put it in, he got it in but the rubber tore on one corner so he ordered another rubber and got it right after 3 trys. There's a guy that lives near me that can put one in with his eyes closed in 5 or 10 minutes. He has about 5 or 6 trucks now. He did have a lot more but I talked him in to selling a few of them (I bought one). I told him the reason our trucks are hard to find around here is because he had them all!
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 01-17-2003, 04:26 AM   #6
baggedblaz
the gasket usualy puckers because the trim isnt in the groove correctly, did he tape the trim into the rubber? is it new rubber? usualy if you loop the rope at the top and bottom it helps to pull the corners lots of lube helps too! i do glass and have done way too many of these to count i have seen almost all goofy stuff with these including the so called new trim (doesn't fit too well btw)good luck !!!
if you have questions holler i can try to help?
'82 chev swb 4dr 2wd project
'72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's
'71 2wd blazer
'95 chev 2wd Xcab swb
baggedblaz is offline   Reply With Quote
