Old 08-12-2009, 02:42 PM   #1
TomsCheyenne
Gauges...........
........I want to add factory gauges to my '71. (No tach.) A member here has a correct dash harness, is that all I need? Does it use the same engine harness? Thanks.
TomsCheyenne is offline   Reply With Quote
Old 08-12-2009, 02:54 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Gauges...........
You will need the headlight harness from a full guage truck as well because of the anmeter gauge. The engine harness (starter, coil, temp sender) is interchangeable, so you can use what you have (just tape off the oil pressure switch wire). You'll also want to get a temp sender unit for guages from the auto parts store and the oil pressure line and fittings off a donor truck.
FYI, I'm pulling those inner fenders tonight
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-12-2009, 06:26 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
You also have to move a wire on the dash harness connector. There's a FAQ on it in the FAQ section.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
