Old 01-10-2003, 03:58 PM   #1
7T1BURB
Upper Ball Joint Boot ?
Need your help....installing new ball joints (MOOG) in the Burb and have a question about installation of the upper ball joint rubber boot...does the boot install from the top of the A Arm first, then the ball joint OR does the ball joint go into the upper A Arm first and the boot installed from the bottom of the arm??? Logic might dictate that the boot goes into the upper A Arm first, but it seems to be a really tight fit!! Thanks for your help !!!!!
7T1BURB is offline   Reply With Quote
Old 01-10-2003, 04:06 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Ball joint goes in (from top) and then slip the boot on from the bottom. I put a little grease on the boot to get it to slip up on the joint all the way and help seal it off.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-10-2003, 04:40 PM   #3
7T1BURB
THANKS 71Stepside !!....I'm off to garage to install the boot and ball joint.............
Old 01-10-2003, 04:47 PM   #4
1971Stepside
Almost Satisfied
Your welcome. I torqued the nuts on the bottom side before I slipped the boot on because it gets in the way of the socket. I also had to tap around the lip of the boot with a flat edge to get it all the way on there.
The bottom ball joints and boots and me are still having disagreements!! Good luck!
Old 01-10-2003, 10:54 PM   #5
7T1BURB
Uppers are in .............However, I'm now experiencing the same problem with the lower ball joint boot you are having. I've pressed in the lower from the bottom, but lo and behold the boot (even when correctly seated on the ball joint) rises up off the ball joint after being flush when I let it go....rises about 1/8 " above the lower A arm.......oh well, tomorrows another day. If I figure out how to make the lower ball joint boot remain in place I'll give you a shout.......Again, thanks for your help!!
Old 01-11-2003, 12:55 AM   #6
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
hmmm
Lower ball joint boots...seemed to slip right in when I helped my dads freind with all the front end stuff...I can't really seem to understand the difficulty. The hardest part for us was installing the lower ball joints!! Oh well....is there a difference between the front end parts on a 68 from a 71??? Aside from disc brakes.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
