08-12-2009, 05:40 PM | #1 |
need info on 5 lug conversion 66 rear end
have a 65 c20 found a 66 1/2 ton rear end but want to convert over to a 5 lug. have seen the axles from early classics but want more options.
thanks... Last edited by wrench_65; 08-12-2009 at 05:44 PM. |
08-12-2009, 06:02 PM | #2 |
Re: need info on 5 lug conversion 66 rear end
I replaced mine with Superior Axle and Gear axles. They're a direct fit from Summit. Not cheap if I remember right. I think they were 130 a piece and then I bought and pressed in some new studs. Maybe someone else can weigh in with a cheaper option.
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 08-12-2009 at 06:03 PM. |
08-12-2009, 06:30 PM | #3 |
I did like alot of the others. I found a '72 and swapped the rear end.
08-12-2009, 06:59 PM | #4 |
Does the 72 bolt Right up? Have coil spring reAr end..
08-12-2009, 07:07 PM | #5 |
Senior Car Nut
'71 and '72 are trailing arm, coil springs just like ours, but with 5 lugs (5x5) (mine is a '66 with '71 front and rear). bolts in but is a total of 1.5 inches wider.
Larry |
08-12-2009, 07:21 PM | #6 |
performance online has full conversion kits with new drums. Might want to check them out.
08-13-2009, 12:33 AM | #7 |
60-66 Nut
Another option is plugging and redrilling your existing axles. This probably wouldn't be much less $$ than buying new axles unless you could do all the work yourself. Just be sure your wheel bearing surfaces are good on the axles before you decide to plug and redrill.
08-13-2009, 02:36 PM | #8 |
the 71-72 rear end since it 1.5" longer is there a problem when lowering the rear say 4 to 5 inches as far as rubbing issues??/ gonna be running 15" supremes on 205 70 15
08-13-2009, 03:15 PM | #9 |
Watch out for your cornhole !
I'm running a 72 model rearend in my junk with 8 inch wide wheels and 275/60 tires, all lowered 5 inches. No rubbing at all.
08-13-2009, 03:52 PM | #10 | |
08-13-2009, 06:54 PM | #11 | |
Senior Car Nut
Larry |
