James
Lower balljoint separation w/o balljoint separater??
I'm trying to separate my lower balljoints so that I can cut my springs down. They have never been apart before so ya, the're in there good. I've tried many, many idea's of my own and I just can't seem to get enough leverage to apply enough pressure to break it loose. I don't have the funds to buy a separater tool and can't find one anywhere. What would you do or what have you done to accomplish this?
Pics are always a good thing. Thanks guys, James
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
Keepin it old school
Re: Lower balljoint separation w/o balljoint separater??
Big hammer. Whack the hell out of the spindle right beside the balljoint. Swing from the side. You have to hit it HARD.
1961 crewcab
do you have an oreillys parts store near by, they will loan the tool to you for free..
or how about leaving the spindle hooked up and just unbolting the control arm from the frame? |
![]() Join Date: Sep 2006
You may consider creating a bolt to the floor plate, if your concrete is good, then just strategically wrap a chain around the a-arm, perhaps through the spring to protect the arm, then bolt the chain to the plate and jack up the tire, don't jack up the truck as you will just flip it over, you could bump it with a hammer after getting a little tension, but not too hard. The floor plate can be made recessed so you can drive over it too. I had one in my old shop, it came in very handy, I have yet to do one at my new house, and have had many a time where I wish I had it.
#5 | |||
James
Thanks guys for all the suggestions. I just got extremely frustrated and felt I had to post for more ideas on this.
I use a couple of bolts and a coupler. I have two 1/2" course thread bolts connected with a coupler, which is a 1-1/2" long nut. I put a wrench on the coupler so it does not turn and back out the top bolt. My top bolt has the head built up with weld and then ground down with a grinder to give it a shallow cone on top. This helps keep it from walking off. I get it as tight as I can then if it does not pop, I give it a wack with a ballpeen hammer with the round end. It is what I use when I go to the junk yard. By the way the ballpeen is like 20 plus onces, big sucker. I think it would work better if it was fine thread but that was all I could find at Ace Hardware. Oh before I forget, I leave the ball joint nuts on but backed off to the end of the threads.
