Old 08-12-2009, 06:28 PM   #1
87Bob
Anyone know what the computer in an 85 does?
I am trying to figure what the computer in an 85 does and how to dump off the truck? When I make my engine swap I want to get rid of the Q Jet and go with something more tune able.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 08-12-2009, 06:57 PM   #2
tylerg.
Re: Anyone know what the computer in an 85 does?
1985 c-10's have computers?
tylerg. is offline   Reply With Quote
Old 08-12-2009, 07:05 PM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Where is said computer?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 08-12-2009, 07:12 PM   #4
bigbadjohn84
they controlled the spark in some of the computer controlled advance in the big cap HEI units as well something in those 80's junker QJets. no offense. the early model QJets are not as bad as everyone makes them out to be though.
bigbadjohn84 is offline   Reply With Quote
Old 08-12-2009, 07:17 PM   #5
thump16
thump16's Avatar
same as 84 c-10. The computer is Located behind the glove box mounted under dash in that area(metal box with wires going into the engine bay). Look up ESC computer. It controls spark through your distributor and when it goes out it gives all kinds of false symptoms from bad timing to fouled plugs. There are a few write ups on how to disable it on this forum and the link below.
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
I ditched mine and ran a HEI distributor and I also helped a buddy run his stock distributor by following the directions given in the how to write up.
thump16 is offline   Reply With Quote
Old 08-13-2009, 02:55 PM   #6
bigbadjohn84
I second that. disable it, you'd be glad you did lol. it's junk
Old 08-13-2009, 03:09 PM   #7
Sniper X
All they were designed for is to try and get better mileage out of a carbureted truck with the carby. After the carb went to a TBI or injection, the computer took care of all sorts of stuff like anti knock, timing, spark advance, fuel rations and other stuff. Back then, all it controled was the HEI distributor. I feel if you bought a normal HEI and swapped it out you would be better off.
Sniper X is offline   Reply With Quote
Old 08-13-2009, 04:51 PM   #8
Jonboy
Slots go on anything!
The computer in your 85 will listen for knock, and pull timing accordingly, if needed.
Old 08-13-2009, 04:57 PM   #9
JohnC
JohnC's Avatar
They mainly take up space.
JohnC is offline   Reply With Quote
Old 08-13-2009, 05:16 PM   #10
60ratrod
yes, i do
60ratrod's Avatar
did it take one of these to tune??
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 08-13-2009, 05:16 PM   #11
60ratrod
yes, i do
60ratrod's Avatar
or how bout one of these??
Old 08-13-2009, 05:18 PM   #12
Jonboy
I have always heard to use a paper clip to put it into field service mode, then use the Pong controller from a Colecovision game to run it.
Old 08-13-2009, 05:20 PM   #13
Sniper X
Right, and to do HP mods, you could use a Pac Man game card, just plug it in and the truck would handle way better!
Old 08-13-2009, 05:26 PM   #14
Manbearpig
Manbearpig's Avatar
My 84's computer controls the choke and spark advance I believe.
Well it doesn't anymore, but it did.
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 08-13-2009, 06:38 PM   #15
bigbadjohn84
Old 08-13-2009, 08:20 PM   #16
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
What was the first year for computers I always thought it was 87? Did all trucks have em or just ones in states like California.
1985-GMC is offline   Reply With Quote
Old 08-13-2009, 09:58 PM   #17
andrewmp6
The mid 80s gm put the same set up on everything.My 83 grand prix had the same useless ecu thing on it a simple carb and dizzy swap its gone.
andrewmp6 is offline   Reply With Quote
