Primer or Seam Sealer First
Removing paint with 80 grit sand paper and plastic paint remover attached to high speed. When I get ready to shoot primer do I seam seal the cab top before or after the primer? What is your experience and did it work okay? Thank you in advance.
Re: Primer or Seam Sealer First
Prime first,seal,and prime.
What I have always done and it has worked out really well for me and others is do all your body work so you are ready for paint then do your seam sealer and spray your paint. You want the surface prepped the same for sealer as you do for paint. But also keep in mind anything is better now a days then what the factory had be then!
Kevin LFD Inc. |
#4 | |
Chevy Truck Addict
![]() Join Date: Aug 2006
It's almost like caulking before you paint a house... It's applied just before you paint. The way we applied mine is similar to caulking a house - Apply a bead and smooth it out with your finger. Instead of water on your finger, use some reducer and have plenty of rags handy to wipe of the excess. It's a little hard on the fingers but worth it if you want a nice smooth bead.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Just make sure it`s cured before painting.i`ve seem paint crack when coated too soon.but,the main thing is you shouldn`t apply ahead of priming.I use high-build primer,sand,then shoot tech primer.I usually seal between primers.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-13-2009 at 05:06 AM. |
Thank you all.
#7 | |
Our you can do it like the factory and just slop it on then wipe the excess in an area no will ever see for a while ![]() |
or let it drizzle down the inside of the door pillar
Broken Back Club 72 Club GMC Club Panel truck Club 6 cylinder Club Unfinished Projects Club Outdoor Sportsmens Club |
I'm still removing the paint, never realized how difficult and tedious the job really is but I got all the sealer off the roof drip edge. I was real lucky very little rust. Learning to be real patient.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Paint always seems to not want to come off unless its rusty paint... Btw I always seal everything 1st them move on from there...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Nov 2006
I thimk i,am gonna put some epoxy paint on my drip rail before i put the seam sealer on. I used a coarse wire brush in my die grinder to clean everything up.
I BELIEVE IN JOHN 3:16 |
What do you use as a seam sealer? I mean is it a specific product or something I can pick up at the hardware store. I ask cause I'm gettin' ready to clean up the drip rails on my truck and hadn't realized there was even such a thing as seam sealer.
#13 |
Go to your local body shop supply store - 3M has a couple of products that will work good.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 08-14-2009 at 11:43 PM. |
#14 |
#15 |
SWB 4X4 CLUB
I just sand blasted mine then epoxy primer. The seam sealer will go on next then the paint.
Jason |
#16 |
Dont use nothing but 3m seam sealer cauz its the best made. It costs twice as much too. Like 18-22 bucks a tube
#17 |
69 Fleetside
![]() Join Date: Mar 2009
Use nothing but 3m 8307 automix...I used a couple products beforehand and found myself redoing it twice before finally getting this product...One tube and gun rental from my local bodyshop ran $45 and the finish is stellar...I learned my lesson so you don't have to!
