the pollock
buying cross over
anyone knwo where to buy a kit fro crossover?
thanks
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
Re: buying cross over
Off Road Design
Dana 60 http://www.offroaddesign.com/catalog...0crossover.htm Dana 44/10 bolt http://www.offroaddesign.com/catalog...4crossover.htm
05 1500 Crew Cab 79 K10 Scottsdale 71 K10/Custom 85 K30 CrewCab 72 Camaro |
the pollock
OMFG that's expensive... yeap my wife instantly vetoed that one...
dang... maby i'll luck out and find a used one...
![]() Join Date: Feb 2009
That doesn't include the price of the 2WD steering box or flat-tops either...
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
Do you plan on wheeling your truck? How much lift does your truck have? If you just plan to dd/cruise then you maybe able to get by with the standard steering corrections.
05 1500 Crew Cab 79 K10 Scottsdale 71 K10/Custom 85 K30 CrewCab 72 Camaro Last edited by konajoe; 08-13-2009 at 06:51 PM. |
I made my own. Being a machinist has its advantages.
![]() 2wd power steering box from the warehouse. (out back of the house) 1 ton drag link ends from NAPA Pc of round bar for the drag link steering arm from Mad FWD, with studs, cones and nuts pitman arm from a 78 Ford F150. flat top knuckle was on the Blazer already. The boss bought me the LH tap for the drag link. I had to buy a tappered ream for the steering arm and the pitman arm. Then i took everything to work and went to town. I had to heat up the pitman arm and bend it a little so it wouldn't hit the frame. So far so good. No failures.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
![]() Join Date: May 2007
Check out the "how to" on colorado k/5. This guy did his own and did a few things to lower the cost. It is a good read.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Sofa King. We, Todd, Ed.
I really like the kit I got from Blackbirds: http://www.blackbirdscustomtrucks.com/
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
Not sure what you have for an axle but I just bought these arms for my d60.
http://www.ballisticfabrication.com/...es_p_1246.html |
the pollock
8 in lift
on corp 10-bolt front running 37's.... hmmmmm... well all this is because my stock steering stabalizers are now kaput... cannot compress or extend one of them.. adn teh second goes in and otu too easily.. and not with a full range of motion either.. thnaks..
#11 | |
Plus I am on here to answer any questions you might have...
Support The Board |
Coolio. So a 2WD box is all that is needed for the 44 correct? Works with '73+ as well?
#13 |
Yup, a truck 2wd box
Support The Board |
#14 |
the pollock
ok..
well iw as roaming the junkyard this week and i had yet ANOTHER cross over question i have my D44 knuckel NOW.. i noticed on some of the camper specials and k20 series trucks that they have the 2wd set up that looks like cross over.. (look at the 2wd parts uptop) http://www.lmctruck.com/icatalog/cc/full.aspx?Page=139 can i use any of this to build my own? i am determined to make my own without it looking god awful and dangerous
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 Last edited by dammitmitchell; 08-25-2009 at 04:40 PM. |
#15 |
The only thing you need there is the 2WD steering box.
#16 |
the pollock
damn..
well it was tempting.. so.. 2wd steering box.. and knuckle coming in... what do i have to tell the machine shop to mill? or should i just wait until the highsteer arms come in and then have them "match" it ..?
#17 | |
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#18 | |
If the arm comes with out a tapered hole for the TRE, then give him the TRE too so he can try it.
#19 |
You will have a problem with the center link. D44 flat top knuckle TRE's come down from the top. 10 bolts come up from the bottom. Are you going to use matching knuckle's?
You cant mix and match.
#20 |
the pollock
both will have the aftermarket high steer arms,
so then the tie rod ends should be matched then..... right? how would the stock locations effect aftermarket parts? i can go get another d44 knuckle but i havent been seeing both come in a kit for the crossover kits labeled for "d44 and corp 10" come with all the same equipment...
#21 |
If you were just doing crossover, it would matter because the center link ends go in from the top on a D44, and up from the bottom on a 10 bolt.
But...since your doing high steer (you said crossover not high steer) you could probley get away get away with the 10 bolt knuckle on the driver side. You should keep your knuckles in pairs. But...do what you have to do.
#22 |
the pollock
sweet..
i was freaked out and was hoping it was a misunderstanding, with most "highsteer/crossover? kits it pretty much seems to only be the pitman arms that are changed.. (or whatever the name is for the arm on knuckle itself)
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 Last edited by dammitmitchell; 08-26-2009 at 10:43 PM. |
#23 |
steering arm
