Old 08-13-2009, 07:01 PM   #1
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Chevy 10 Bolt Diff w/22x11 rears
Question guys, im thinking of using a chevy 10 bolt rear with 22x11 rear wheels is it possible to fit these without modifying the diff meaning without shortening?
Sweet 85 C10 is offline   Reply With Quote
Old 08-13-2009, 07:16 PM   #2
LONGHAIR
Re: Chevy 10 Bolt Diff w/22x11 rears
That is completely dependant upon the back-spacing of the wheel, the size of the tire, and the amount of drop on the truck.
Essentially and unanswerable question w/o more info
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-13-2009, 08:42 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm assuming this is for a truck that is bagged.... and assuming you plan to highly modify the inside of the bed (sheet metal).... and assuming you are ordering billet wheels with custom back spacing... and assumnig none of your link bars or bag brackets aren't in the way...
no problem.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 08-13-2009, 08:45 PM   #4
AirMale
AirMale's Avatar
6.5" back spacing, no leafs springs and mini tub and your good!
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 08-13-2009, 09:02 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by smashingchuck View Post
I'm assuming this is for a truck that is bagged.... and assuming you plan to highly modify the inside of the bed (sheet metal).... and assuming you are ordering billet wheels with custom back spacing... and assumnig none of your link bars or bag brackets are in the way...
no problem.
You forgot one. You are also assuming it's for his Sweet 85 C10.
Give us a few more details, and we can help a whole lot better.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-13-2009, 09:05 PM   #6
smashingchuck
78 Build Thread
4Runner Build
Old 08-14-2009, 09:03 AM   #7
Sweet 85 C10
OG
Hey guys sorry about that, so heres the story not so long ago I purchased a Ford 9 inch rear diff which is obviously more narrow then most chevy rear diffs. Now I have decided I wanted to stay with my stock 10 bolt chevy diff and wanted to run 22x11 in the rear. yes bed floor will be modifyed and no bars will be in the way like a 4 link or anything, im actually going to a cantilever lift system from SD and a 3 link bar system.
Reason im asking this is because I have seen a few guys that never shortened there diffs running this type of wheel combo. Ill be running a 6.71 backspacing on these wheels with a +18 offset. Im going to assume I should be all right but wanted to know for sure if someone has a similar setup.
Old 08-14-2009, 09:29 AM   #8
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
narrowed.. but close to what your looking for right?
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-14-2009, 09:38 AM   #9
Sweet 85 C10
OG
Yeah exactly except those are way bigger then 22x11 LOL!!! But yeah do you have any close up pics of that system?
Old 08-14-2009, 10:46 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
WOW! camaro__thunder you gotta give us more pics.
Articles-
"Refining Sierra"
Old 08-14-2009, 01:12 PM   #11
au03z71
au03z71's Avatar
You plan on running those KMC Novas?
au03z71 is offline   Reply With Quote
Old 08-14-2009, 01:28 PM   #12
Sweet 85 C10
OG
YUP I already have the front ones and before I install my rear axle wanted to know if I had to shorten it to do the 22x11 rears 6.71 backspacing
Old 08-14-2009, 05:11 PM   #13
au03z71
au03z71's Avatar
How do they fit? Are they 22s?
Old 08-14-2009, 05:13 PM   #14
smashingchuck
They should tuck just fine. You might even end up with a 1/2" spacer.
78 Build Thread
4Runner Build
Old 08-14-2009, 05:29 PM   #15
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Yikes.......that is COOL!! What size rim & tire out back??
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 08-14-2009, 05:32 PM   #16
smashingchuck
78 Build Thread
4Runner Build
Old 08-14-2009, 06:10 PM   #17
Sweet 85 C10
OG
So basically what your saying is I can still use my stock 10 bolt rear with no probs I just want to confirm?
Old 08-14-2009, 06:42 PM   #18
smashingchuck
Yep. Here a picture of a 20x10 with 5.25 backspacing. The face of the wheel is about as close to the bedsides as you would want to get, so with a 11" wide wheel you'll want the extra inch to be on the inside; based on that, I'm coming up with 6.25" minimum of backspacing. I think wheels look best when they are as close to the fenders as possiable, which is why i said you migh end up with the .5" spacer.
78 Build Thread
4Runner Build
Old 08-14-2009, 07:10 PM   #19
au03z71
au03z71's Avatar
Where did you buy your wheels from? I was thinking about getting these a while back but I didn't think they came in 5x5.
