01-10-2003, 06:35 PM | #1 |
Back wheel locking up.new brakes?
My back wheel (drivers side is locking up very easily) locks up and I am not sure why, Ima newbie when it comes to this stuff.
I want to do a brake job, does anyone sell kits? What brand of parts do you guys use and reccomend. Thanks ~72~ Pete |
01-10-2003, 07:36 PM | #2 |
I would check to see if the wheel cylinder is leaking if it is you need to replace the shoes too
72 Custom Deluxe, Viper red with a 383 HT |
01-10-2003, 09:42 PM | #3 |
A leaky axle seal can make that happen also. Bottom line is you are going to have to pull it apart and inspect it.
01-10-2003, 09:58 PM | #4 |
14.1 @ 96MPH
Yup...when mine did it, it was wheel cylinders.
Project1970 - LS1 Swap Complete! |
01-11-2003, 10:14 AM | #5 |
1969 Custom 30 wrecker
Next time you notice it locking up, pull over and feel the wheel/drum carefully. If it's very hot, you have a brake locking up most likely due to a bad emergency brake cable.
I've had this on my truck and a Blazer I used to own.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
01-11-2003, 10:21 AM | #6 |
Yep, i'd say leaking wheel cylinder. I had that same problem and found a bad wheel cylinder...
