Old 08-14-2009, 12:19 AM   #1
hotrodrookie
hotrodrookie's Avatar
task force radiator..
Im going to need a radiator soon my 59 and right now i have all the sheet metal off but was wondering how wide of a radiator can I use without cutting into stuff. Im looking at a 02 camaro with dual fans and it looks wider then what i think will fit.
Measurments or guestiments are welcome
hotrodrookie is offline   Reply With Quote
Old 08-17-2009, 11:09 AM   #2
chris71
chris71's Avatar
Re: task force radiator..
unless you modify the core support to allow more air flow to the wider radiator, a wider radiator wont do too much for you, even with e-fans, the air has to flow through the rad, and it cant be blocked, unless you have a crazy motor in her, a stock rad will do fine, i put a 4 row 55 car rad in my 55 2nd series, the car rad is a few inches shorter and it looks better IMHO. I think the stock width is as wide as you can go without modifying the core support.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 08-17-2009, 11:24 AM   #3
OrrieG
OrrieG's Avatar
Big truck radiators are 1" thicker and 1.5-2" wider and bolt in the stock location. I ran a stock 6 cylinder radiator with my 283/th350/ 4wd set up and never had over heating problems with that. I got the big truck radiator for free because of the larger engine and I am adding AC. Here is a photo of the big radiator trial fit. The shroud was mounted about 1.5" high in this photo. I fabbed a closure piece for each side and used the factory clips to mount it.
OrrieG is offline   Reply With Quote
Old 08-17-2009, 11:32 PM   #4
hotrodrookie
I actually went and bought the camro radiator with dual fans, it should **** and work nice with the 5.3
