Fat Fendered Fleetside
Mordachai- High Rise Fiberglass Fenders- Group Buy
Group buy for ___________________________________________ High rise / radiused fiberglass fenders These are fiberglass fenders with wheel openings that are 4" longer and 2" taller with a factory look. Great for slammed trucks or lifted trucks looking for a little more wheel/tire clearance. 67-72 GMC & 67-68 Chevy style fender: ![]() ![]() 69-72 Chevy style fender: ![]() ![]() These are top quality parts, ready to fit and 'scuff and spray'. There are no pinholes, bubbles in the laminate, or other problems often associated with fiberglass. Sub-par parts will NOT be shipped out- EVER. Each fender will be warrantied against manufacturing defects for a period of one year from purchase. Option 1- Outer skin only: This can be bonded to the 'frame/skeleton' of your existing fender, or have custom mounts built. Option 2- Full fender with factory mounts: This will bolt to the factory locations, 2 bolts on cowl, 1 bolt on lower A pillar, and factory bolts on the Core support. This fender will require some fabricating to brace the cowl support in position(preferably from firewall/cowl to core support). Additionally you will need to fabricate new mounts for your hood. This can be done either by installing firewall/cowl hood hinges or fabricating mounts to use the stock hood hinges. Dropped trucks will probably need firewall/cowl mounted hinges, 4x4 trucks can use whatever method is found suitable. Standard Pricing: Option 1-a Lay-up with gelcoat, vinyl-ester resin, woven cloth and 2mm core = $350 Option 1-b- Lay-up with gelcoat, Poly-ester, CSM and 2mm core =$300(CSM- chop strand mat) Option 2-a- Gelcoat, Vinyl-ester resin, 2mm core and woven cloth = $475 Option 2-b- Gelcoat, Poly-ester resin, CSM, 2mm core = $425 Shipping is going to be either UPS ground oversize, UPS Freight, or truck freight, your preference. shipping will vary due to buyers location, ships from zip 33414. I have sourced 'oversize' shipping boxes that will work perfectly for the fenders, and all other packing materials. Group buy pricing prices are Per fender. GB pricing for total overall sales, not for each separate option Option 1A Retail: $350 1-5 committed :$325 6+ committed : $300 Option 1B Retail: $300 1-5 committed :$275 6+ committed : $250 Option 2A Retail: $475 1-5 committed: $450 6+ committed: $425 Option 2B Retail: $425 1-5 committed: $400 6+ committed : $375 Committed sales require min. 50% deposit, Balance & shipping due upon completion. Payment through paypal, MO or personal checks. available now: 67-72 GMC style and 67-68 Chevy style available early october: 69-72 Chevy style Lead time for 1 pair of skins = 2 weeks after 1st GB rate reached Lead time for 1 pair of fenders with bonded mounts = 3 weeks after 1st GB rate reached
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
Re: Mordachai- High Rise Fiberglass Fenders- Group Buy
Nice job,I will keep you in mind if i hear of anyone needing fenders or for my future builds.
USMC
those look good do you have a picture of them installed on a truck/blazer with wheels on it?
Semper Fi |
do you also make bed panels
Also all of the above can be made custom to your needs: Can be made with epoxy resin, kevlar, or other custom options (colored gelcoat, thicker core, etc)
Kevlar layer = + $150 S-glass instead of E-glass = + $75 Colored gelcoat = + $25 double thick core = + $50 Shaved sidemarker = + $50 Post here or PM for pricing beyond the above custom options. This group buy will run until September 18th. Please feel free to PM me with any questions or comments. Last edited by Mordachai; 08-14-2009 at 10:40 AM. Reason: Thanks Ken! |
