08-14-2009, 08:53 PM | #1 |
gauging it
My truck is a 64. The PO chose to forgo the factory gauges in favour of some aftermarket ones mouted under the dash. I want to hook up the factory gauges so I can remove the underdash ones but have never been one for electrical issues so I need some help with how they should be connected. The aftermarket temp gauge uses a probe so I will need to replace thet with a sending unit, that's fine, but the factory gauge has 2 terminals that I assume are one to the SU and the other to ground. If so, which is which?. The Batt gauge also has 2 terminals but is this a volt or amp gauge?. does it matter?. The plugs are wired into a harness and go ????? somewhere. I don't LIKE to leave unused wire in the harness but, unless there is a way to trace where they go, I will have to just run fresh wires from the gauges to there respective destinations. Any help would be greatly appreciated. The oil gauge is OK, it's mechanical
Thanks C |
08-14-2009, 09:06 PM | #2 | |
Hollister, CA.
Re: gauging it
The temp guage use one term for the SU and one for the 12 volts, not ground. The SU sends a 'ground' signal to the guage, which varys with resistance (temp. change). The Batt guage is probalby a volt guage, that just needs 12volts (key-on) and the other terminal to ground. My truck has a guage cluster, but haven't looked behind...the back of the guages are usually labeled. The wiring is color coded...that should help you trace.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-14-2009, 09:33 PM | #3 |
Re: gauging it
Here' are some pics of the back of the gauges. So I would put a wire from the terminal connected to the large coil on the batt gauge (gauge on the right) to keyed power and the other to ground....right?.
For the temp gauge, would the SU wire go to the large green coil or the smaller red one?? The wires are colour coded but they go to a plug then exit and dissappear into a large harness that goes in three directions that are next to impossible to follow. |
08-14-2009, 10:29 PM | #4 |
Senior Enthusiast
Re: gauging it
The following links may be of some value to you. The first shows the wiring diagram, and the second has a bunch of different wiring related links at the bottom of the page:
http://67-72chevytrucks.com/vboard/s...d.php?t=193429 http://www.6066gmcguy.org/wire-tips.htm |
08-14-2009, 11:26 PM | #5 |
Resistance is Futile
Re: gauging it
Not sure about standard factory options, but these trucks had a cold lite that lit when first started. This could be one of the terminals on your guage....not sure. That is NOT a volt guage in the dash, it is an amp meter. It needs to be connected thru the positive battery wire after the load of all the dash and electrical components....be careful with this gauge as it can start a fire if not properly wired and the wiring is in bad shape. Just some info I have learned......copy these too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
