08-14-2009, 09:10 PM | #1 |
4x4 cabs
I am dealing with a '72 K20 and need another cab. Can a 2wd. cab be used? I've heard the term high hump used, is this a removable panel that can be put in the 2wd cab? Thanks Wes
Wes Last edited by 2006GMC; 08-14-2009 at 09:10 PM. |
08-14-2009, 09:48 PM | #2 |
Roadtrip!
Re: 4x4 cabs
Any 4x4 cab or 4 speed cab had the bolt in hump and alot of bigblock/400 cabs did also. The 2wd cab can be converted, but it is some extra work.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-14-2009, 10:08 PM | #3 |
70 Chevrolet=Obsession
Re: 4x4 cabs
If it's a 2 wheel drive cab with a high hump you can just bolt in the 4 wheel drive high hump and you have the proper openings. If it's a 2 wheel drive low hump (like a 6 cyl 3 on the tree) you'll have to cut out the low hump and weld in a high hump. BTW, If you got a 4 speed manual in your 4x4 you have to consider the extra hole in the replacement hump plus the hole for the high/low shifter.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 08-14-2009 at 10:11 PM. |
08-15-2009, 06:29 AM | #4 |
Re: 4x4 cabs
The low hump floors accept the high hump perectly.You can lay the high hump right in place.There is the cut line already.Just cut and install.You`ll want tack weld nuts on the back side of the holes for easy installation and removal.
08-15-2009, 01:22 PM | #5 |
Re: 4x4 cabs
Thanks for all the help guys. I won't get to jazzed if I find a good low hump cab now.
Wes |
