Old 08-14-2009, 11:21 PM   #1
jaymc32
67 or 68??
I've got a 72 and was thinking about checking out this truck for parts:
http://washingtondc.craigslist.org/n...318464844.html
He claims its a 67, but it has front marker lights. I'm new to these trucks but does it not look like a 68?
If it is a 68 would the fenders work on a 72?
jaymc32 is offline   Reply With Quote
Old 08-14-2009, 11:24 PM   #2
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: 67 or 68??
Big rear window? Very likely a '68 but you never know until you check the title.
I don't believe the fenders will work on a '72, but I could be wrong.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 08-14-2009, 11:25 PM   #3
mclairmo
Re: 67 or 68??
If it has marker lights front and back, its a 68. You will need entire front clip to swap, including radiator core support, fenders, hood, grill, etc.
mclairmo is offline   Reply With Quote
Old 08-14-2009, 11:47 PM   #4
jaymc32
Re: 67 or 68??
Thx guys, this forum is great!!
Lets say I go look at this 68 and find that its in pretty good shape as the add says. My 72 is pretty rough but it does offer a nice 350 GM crate motor with a solid trans and a ps setup. The 68 most likely has drum brakes and manual steering. Can I just knock the spindles out of the 72 and throw them in the 68? Would the ps swap be straightfoward?
Old 08-15-2009, 06:16 AM   #5
Re: 67 or 68??
The seller could only come up with 5 year old pictures?That makes me a bit shy.It could be a`67 with the bed and fenders replaced.It`s restored,afterall.The big window means nothing.They were available in`67,just an option.The bonified way to tell would be in the dash.The lighter isn`t recessed,the knobs are smaller,the ash tray id thin at the face,the heater control face is different,the ignition switch is smaller diameter,the mirror is unique,and if the wing vents are original they will have diferent latches.The same goes for the interior handles on the doors.
Old 08-15-2009, 09:38 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 67 or 68??
those fenders would not work as a direct replacement on your 72. The entire front end (hood/fenders/grill/core support) will swap onto your 72 though.
Disk brake conversion isn't quite that easy, I think you need to swap out one of the A arms and tie rod ends or something. While I've only done it once, I swapped out the entire crossmember, from wheel to wheel.
in this part of the country, that is a screaming deal if it looks as nice as in the pics.
Old 08-15-2009, 01:00 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 67 or 68??
Cant hurt to at least go look at it.. Make sure ya take pics then we could really tell ay whats going on with that truck..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-17-2009, 06:26 PM   #8
jaymc32
Re: 67 or 68??
Thanks for the input on this folks.
I had noticed the pic dates as well, was hoping he just didn't set the date in his camera.
I went and took a look at the truck today. Ever notice how your truck always looks better in a picture, I know mine sure does. That was certainly the case here. That poor old truck just plain looked sad, tired and abused. Lots of bondo, rust and the interior was stripped to boot.
Owner wasn't home and I didn't have a camera so I'm still not sure what year truck it was.
Old 08-17-2009, 09:16 PM   #9
Re: 67 or 68??
Sounds like the pictures "were" 5 years old.
Old 08-17-2009, 10:10 PM   #10
danw210
69 K20
Re: 67 or 68??
Most likely a 68. Big window was an option in 67 but side marker lights were not available.
danw210 is offline   Reply With Quote
Old 08-17-2009, 10:22 PM   #11
71swb4x4
71swb4x4's Avatar
Re: 67 or 68??
Do you have Chevrolet or GMC? It appears others may know already, but just in case, there may be a slight glitch in the advice above.
If your 72 is a Chevy, they are right that the fenders are not the same as your 72 Chevy fenders. However, if you have a GMC, the 68 fenders are exactly the same as your 72 GMC fenders.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-17-2009, 10:28 PM   #12
kev2809
low n' slo
kev2809's Avatar
Re: 67 or 68??
no, but doesn't the 68 fenders just swap on the 67 front end? maybe he put 68 fenders on the rest of the 67 clip..? anywho, so you decided to not to get it?
kev2809 is offline   Reply With Quote
Old 08-18-2009, 06:50 AM   #13
jaymc32
Re: 67 or 68??
Sorry bout that, mine's a chevy. Yeah I passed on this one. Only thing I could use off this truck was the doors and bed and they were both pretty rough.
Old 08-18-2009, 09:58 AM   #14
1LoC10
Insert Title Here
1LoC10's Avatar
Re: 67 or 68??
it has markers on the bed too, that would be new fenders and a new bed if it IS a 67
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
