08-15-2009, 12:46 AM | #1 |
Clutch rod hole
I have a 71 GMC that was a 6 cylinder manual and converted to a 350 with a th350 before I bought it. I am wondering what should be used to plug the hole in the firewall for the clutch rod? I am doing the floors, so should I weld it up or is there a grommet or coverplate? I want to go with the stock v-8 auto configuration. Thanks
08-15-2009, 12:52 AM | #2 |
Re: Clutch rod hole
Forget it....see post below...
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 08-15-2009 at 08:23 AM. |
08-15-2009, 05:17 AM | #3 |
Re: Clutch rod hole
There is a cover plate w/gasket that was used on the automatic trucks to cover the clutch rod hole. It is held to the firewall with two small screws.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-15-2009, 09:00 AM | #4 |
Watch out for your cornhole !
Re: Clutch rod hole
You can make one as quick as you can buy one. Make a pattern out of poster board. Then transfer the pattern to a piece of steel or aluminum and cut it out with snips. Dress the edges with a file to remove burrs. Put a bead of silicone around the hole in the cab and screw the cover in place with two small sheetmetal screws. Figure 20 minutes tops.
08-16-2009, 12:12 AM | #5 |
Re: Clutch rod hole
Thanks guys. I could never find the plug that I thought went there and now I know why!!
08-16-2009, 12:35 AM | #6 |
its all about the +6 inches
Re: Clutch rod hole
the older ones had a plastic plug... 69 and older maybe...
