![]() Join Date: Nov 2005
Mix and Match - 68 Chevy fenders and hood with a 71 GMC Grill
I've searched, I read that you can use 68 Chevy Fenders with the later GMC stuff.
Can you use 68 fenders and hood with a later GMC grill? |
Re: Mix and Match - 68 Chevy fenders and hood with a 71 GMC Grill
good question, I would talk to rokcrln since I have seen him modify a few hoods to fit on newer trucks.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
its all about the +6 inches
There's 2 answers... both yes and no.
For a nuts and bolts simple job, I say no. The fenders WILL work, they are the same. The hood though, you'll need a 67-68 grill top bar. You have to drill the rivits that hold the top bar to the grill and then install the 67/68 unit. Then, you'll need a 67/68 hood latch assembly. Then it'll work. |
#4 | |
Thanks for the info. |
#5 | |
This will be interesting then. I better start hunting one down.
thanks Tim... good addition, keeps the confusion down.
Well,I`m not trying to be a nazi(and you know that).Mickey said it would be easy so I wanted to be sure it was.Cuz,simple can end up hard by taking the long road.
![]() heyMickey.just watch for guys swapping 67/68 (GMCs ![]() ![]()
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-16-2009 at 02:02 PM. |
I did this to my 69 gmc, all i changed was the grill top bar and the hood. Is a 67-68 gmc hood latch different from 69-72? I dident change mine, had to run the plunger way out though. I scored the top bar from a board member.
#10 | |
I may actually have one. |
you chainged a 69 GMC into a 68 chevy without swapping the grill or core support?
#13 | |
Exactly, I dont have a pic of mine but heres one i found online. You take your grill and fender moldings off drill out the rivits for the chrome top bar and rivit on the steel top bar. |
#14 |
Old Skool Club
![]() Join Date: Jun 2001
Or, for a lower profile on the '69-72 hood, you could pie-cut it. Seems like the most you can take out on the front end is 1.5 inches, and that is to keep it from contacting the top of the radiator support.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 |
True or another option would be to cut off the leading edge of a 67-68 Hood, I really like the look on 69-72 chevys but on a gmc you might as well just change the grill top bar since thats all that needs changed to run the early hood.
#16 |
Yes.If you look at the front it is slopped like the hoods and the later ones are steeper,like the hoods.But,your`s works fine?I`ve wondered if it really mattered.
#17 |
That's what I am going to do. I can't weld sheet metal all that well.
#18 |
Hmm guess i should pick one up, It works but could be better, plus the plunger is ran almost all the way out. Thanks for the info.
#19 |
Hmn, will a 67-8 Chevy latch work?
