08-15-2009, 11:17 AM | #1 |
c-notch recommendations...bolt in or weld in?
which do you guys recommend? i'm wanting to go lower (yeah i know),..i want to lower the rear about an inch, and that will put my frame a bit too close to the rear housing..so....i want to c-notch the frame, and use one of those adjustable drop shackles to get 1" more of drop
my truck has a 1" rake that is driving my nuts...rear is up little more than an inch than the front so i know i need a c-notch, just not sure if i should get one that welds in, or bolts in? what have some of you guys done? which brands do you rec. or not recommend? thinking seriously about the western chassis one from sport truck direct....dunno thanks guys -by the way, my current set up is: wc 2.5" drop spindles-front wc 2.5" coils -front wc flip kit -rear 245/40-20's -front 295/40-20's rear
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 08-15-2009 at 11:38 AM. |
08-15-2009, 11:45 AM | #2 |
Re: c-notch recommendations...bolt in or weld in?
western chassis c-notch welded
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
08-15-2009, 11:51 AM | #3 |
man, that looks really really sharp airmale!!!!
1987 350 TBI lowered 5/7 |
08-15-2009, 03:05 PM | #4 |
Does a c-notch such as this cause any problems for how the bed sits on the frame?
08-15-2009, 03:31 PM | #5 | |
Happy to be here
Bigzz there is nothing wrong with a bolt in for normal use. If you plan to pull a trailer or haul loads, the addition of a weld in notch with a boxing plate is added peace of mind. As AirMale demonstrated, you can always weld in a bolt in...
08-15-2009, 06:16 PM | #6 |
thanks Ken, thats kind of what i figured......it aint like i'm gonna haul a ton of gravel in this truck or nuttin
08-15-2009, 06:20 PM | #7 |
Happy to be here
I went the opposite direction on mine. I started with a weld in, then converted to a bolt in. Of course there was a bit of motivation to my madness...
