Old 08-15-2009, 02:40 PM   #1
low86c10
lowering my truck
ok well i got my 86 c10 swb, i already have 2.5" drop spindles ready to install and im gonna cut 1/2 or 1 coil.... what should i do in the back flip kit? wiht he flip kit would i absolutely have to do the c notch or just go with out ? or do a shackle hanger kit?
low86c10 is offline   Reply With Quote
Old 08-15-2009, 04:26 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering my truck
Do the flip kit.
Cheaper and doesn't require a c-notch.
Look around the board at what other people have done.
Also,... welcome to the board.
Keith
Convert to disc brakes.
Old 08-15-2009, 04:36 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
flip it cut the bump stop pad from the frame. cut one coil and remove the bump stop from ther as well..
KQQL IT is offline   Reply With Quote
Old 08-15-2009, 05:49 PM   #4
grinch4om
dang its hot
grinch4om's Avatar
I'm in Frankfort..let me help if I can
grinch4om is offline   Reply With Quote
Old 08-15-2009, 09:45 PM   #5
JohnC
JohnC's Avatar
Welcome to the boards. I agree with the others if you are wanting to go 5-6" lower then that is the best and cheapest way to get there.
Also
JohnC is offline   Reply With Quote
Old 08-23-2009, 10:03 PM   #6
low86c10
if you flip it without a c notch will the rearend hit the frame?
Old 08-23-2009, 10:23 PM   #7
lolife99
lolife99's Avatar
You'll be fine without a c-notch.
I've had a couple trucks with a flip kits and no notch. ('86 and '87,... both shortbeds)
Only a super heavy load in the bed will get the frame close to the rear axle.
Keith
Old 08-24-2009, 08:58 PM   #8
low86c10
i ordered a western chassis cnotch/flipkit and drop shackles for the back and ordered ground force drop spindles for the front and ill prolly cut a coil
Old 08-25-2009, 12:33 AM   #9
SCOTI
SCOTI's Avatar
Then you'll wind up w/something like this . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
