Cab paint divider trim ?
Hi guys, is there a way to attach the cab paint divider trim on a cab that has no factory studs/attachments for the clips. Could you drill holes and then set some type of screw to hold the clips in place? Thanks in advance for any help out their.
Re: Cab paint divider trim ?
i've seen small metal screws that held the clips in place work. no problems.
SWB 4X4 CLUB
I am going to try to weld a nail with a similar size head as the the original stud in place. I, however am only missing one stud for some reason. Maybe it will work without replacing it at all.
Jason |
laying low
![]() Join Date: Mar 2001
Back when cars still had shiney trim on them they were held on with small nails and plastic clips. When replacement trim was needed it came with small phillips head screws with thread sealer on them. I'd check with a local body shop to see if they might have some left over or can point you to a body parts supply house.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Apr 2005
Mar-K sells a kit to do this.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
TOTY 2006
![]() Join Date: Dec 1999
Yup, you just get the clips, and measurements from a cab with factory studs (GMCPaul has these measurements) and you just use a #10 sheet metal screw to hold the plastic clip in place. What I did to my 67.
"Trucks with Class"
![]() Join Date: Jul 2000
They make them for welding stud guns---auto body. You do have to strip the area to bare metal to weld them.
I really hate wet sanding!
![]() Join Date: Dec 2008
small rivets work good for attaching trim clips
Thanks again for everyones help. This is a great message board!
