Old 08-15-2009, 05:55 PM   #1
brojoe
Unhappy Exhaust in Blazer
I have a 1971 Chevy Blazer 2WD. lowerd a bit. It is a well insulated vehical with no wholes in the floorboard.
While easing down the Highway (65-70 mph), with my A/C on, I get exhaust fumes in the truck. My exhaust pipes run out the sides in the back (Stock).
Whazzzz up???
Is this common with the older style rear window or what ???
brojoe is offline   Reply With Quote
Old 08-15-2009, 06:51 PM   #2
lks dcvn
lks dcvn's Avatar
Re: Exhaust in Blazer
not common - especially at cruising speeds - is there a leak at the manifold?
lks dcvn is offline   Reply With Quote
Old 08-15-2009, 07:00 PM   #3
brojoe
I do not hear any exhaust leaks.
Not to say there are none.
Old 08-18-2009, 12:03 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
When I was driving my 72 2wd (before I started the restoraton teardown), I had the same problem...it was awful. I found small holes in the exhaust. I replaced the exhaust, and .. problem solved. I suggest you take a rea good look at the exhaust (get underneath and thouroghly inspect).
Tom Vogel is offline   Reply With Quote
Old 08-18-2009, 07:39 AM   #5
vtblazer
vtblazer's Avatar
Very common at speed if everything out back isn't buttoned up correctly.
Do you have a gasket on the bottom of the tail gate?
* Very Important!
Do you have the gaskets running up the sides of the gate?
* Very Important!
Is the upper tail gate seal good?
Are you running the metal srip on top of the tail gate?
Both also very important.
If your not 100% sealed up, you'll get exhaust fumes inside.
vtblazer is offline   Reply With Quote
Old 08-18-2009, 09:26 AM   #6
hotrodhomi
hotrodhomi's Avatar
* Very Important!
* Very Important!
I agree. Although, if you take the top off the smell will go away.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 08-18-2009, 10:51 AM   #7
brojoe
Thank you for the replies.
This gives me two items to look at closely. Exhaust system and tailgate seals.
The rattley rear window is where I will start my investigation.
Brojoe
