Old 08-16-2009, 09:53 PM   #1
tylerdurden
Question How to build a custom front dana 60 ?
I have done numberous searches but can not find any good info about building a home built front axle. My superban project is going along slowly but surly.
I got a rear axle from a 02' 2500HD (single wheel). I say dana 60 but it is really a corporate 14 bolt axle, with 4:10s. I was thinking that if I could cut the axle tube on the passenger side down to 8 1/2" and then weld the remaining tube to the driver side. To make 27 1/2" with a collar to add more strength. I say this so as to stay with in buget. The only other questions are how do the inner seals work and do the tubes need to be lath down to fit the steering ends? I came across some artices about the tubes being lath down, but did not give spec. on size. The tubes on this axle are 3.5 inches and .470 thick wall ( if I remember correctly) Theres a whole kit on ORD website, without any pics. Any help would be appreiated.
tylerdurden is offline   Reply With Quote
Old 08-17-2009, 10:35 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How to build a custom front dana 60 ?
I think you will get a better response in the 4x4 forum. I'll move this over there for ya.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-17-2009, 02:40 PM   #3
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
what are you trying to gain?
avove just a std 60 or even rockwells?
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 08-17-2009, 06:21 PM   #4
cobinder
Everything is work in progress
cobinder's Avatar
What are you wanting to do, move the pumpkin over for driveshaft alignment?
This article is a few years old. But you won't find a more indepth one.
http://www.pirate4x4.com/tech/billav...V60/index.html
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 08-17-2009, 07:11 PM   #5
onlyifihadachevy
I have read about a steering 14 bolt but, i think in the end he said it would have been cheaper to buy a used d60, because you would need inner c's, knuckles, everything and you can get a used 60 for less than a 1000 if you find it in time and they normally sell for about 1100, and think of the cost of machining and welding the cs on. Search on pirate4x4, the general dissucion.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 08-17-2009, 11:03 PM   #6
1969 GMC
1969 GMC's Avatar
x2
so you start with the 14 bolt out of a newer truck (they aren't even as good as the older 14 bolts that have 3 pinion bearings), then you have to buy tube or reuse what you have, then there are the c's, knuckles, steering arms, and you have to machine the tube inside the diff to fit seals, tie rod, etc. you'd be money ahead to just run a used D60 front, and if that isn't big enough it is time for rockwells.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-17-2009, 11:32 PM   #7
onlyifihadachevy
rockwells are 750 + shipping for a steering and 450 + shipping for a nonsteering from 406 yj at pirate4x4, From my understanding if you have clearance the pinions in the right spot.
My 72 thread
Old 08-18-2009, 08:42 AM   #8
duallyjams
duallyjams's Avatar
The show xtreme 4x4 did a 14b front axle.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-18-2009, 08:57 AM   #9
ghettoluxury
ghettoluxury's Avatar
With a huge budget
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 08-18-2009, 03:36 PM   #10
tallhoedude
rockwells can be flipped for left side or rt side pinion,can flip knuckles or chunks.
MY BUILD THREAD:
Old 08-18-2009, 03:37 PM   #11
tallhoedude
there are better prices out there too.
MY BUILD THREAD:
Old 08-18-2009, 06:05 PM   #12
onlyifihadachevy
he said the fronts are normally a little more because of the style but the rears are about 250 but he jacked up the rear to make up for the fronts which most people get to fronts, I woud get 2 fronts and bolt it so the tires stay straight until i get full hydro.
My 72 thread
