Old 08-16-2009, 10:10 PM   #1
Blazer Eagle
Pinion nut
what is the torque specification for the pinion nut on a dana 44 out of a 74 blazer?
Blazer Eagle is offline   Reply With Quote
Old 08-17-2009, 08:50 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Pinion nut
Its around 200 ft lb.
But the inch lb to rotate the the pinion is what's important.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-17-2009, 02:50 PM   #3
Blazer Eagle
Re: Pinion nut
what is the inch lb to rotate the pinion?
basically what i want to know is how do i put the pinion nut back on and make sure it is tight enough/ not too tight
Old 08-17-2009, 09:58 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Pinion nut
If your not setting up the ring and pinion, and just re tightening the pinion nut, then the correct torque is 180-200 ft lb. I always put thread locker on the threads.
What happened, did it come loose on ya. Its happened to me.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-17-2009, 10:19 PM   #5
Blazer Eagle
Re: Pinion nut
no i had to replace th pinion seal
