3/4 ton drop spindles?
Does anyone make drop spindles for 3/4 ton?
If not, can 1/2 ton spindles be modified to work with 3/4 ton stuff? I was thinking you could just drill out the ball joint and tie rod ends with the proper tapered drill bit, but I don't know if the rotor fits the same. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 3/4 ton drop spindles?
They make 3/4 ton 73-87 spindles, I believe. What year truck are you working on?
I used Early Classics without any problems.
69 3/4t
That might work well.
Actually I have a set of ECE 1/2 ton spindles on my 68 that I'm gonna replace with CPP modular spindles. I wonder if they'd trade me spindles.....guess I'll have to give them a call when the time gets closer. |
I don't know about the 67-72's but the 73 later the 1/2t are different then the 3/4t but their the same as the 1t other then how the brake caliper mounts
the 1t and 3/4t spindles shaft are bigger the that of a 1/2 and the ball joint holes are larger
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
