Old 08-17-2009, 02:30 PM   #1
blazer2007
need info on auto column shifter link.
I,m changing from standard to auto column shift,I have the column and shifter rod but no spring that goes in the frame by the tranny.Is it just a spring ,I looked at the wrecker but saw many styles.The truck is a 80 short box,was a six with a 3 on the tree,now a 350 -350,
blazer2007 is offline   Reply With Quote
Old 08-17-2009, 02:46 PM   #2
clinebarger
Re: need info on auto column shifter link.
Theres also a nylon bushing that the spring holds pressure on to keep the rod centerd in the frame
clinebarger is offline   Reply With Quote
Old 08-17-2009, 03:27 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
A friend of mine said you should be able to buy the nylon bushing and spring from a transmission shop. The shop he use to work for sold them all the time...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-18-2009, 01:52 AM   #4
texastruckjunky
texastruckjunky's Avatar
You will also need the bracket that the nylon bushing sits in, that bolts to the frame
texastruckjunky is offline   Reply With Quote
Old 08-18-2009, 09:26 AM   #5
blazer2007
isn,t it the same bracket that was used with a standard clutch?
Old 08-18-2009, 10:34 AM   #6
72 CustomCamper
huh ???
Totally different...
Chuck
Old 08-18-2009, 10:58 AM   #7
Metz
I will look to see if I have a bracket metz
Metz is offline   Reply With Quote
Old 08-18-2009, 12:21 PM   #8
Metz
Smile Re: need info on auto column shifter link.
I found the bracket and the piece that goes from there to the tranny, that piece you may have to modify for your truck
Old 08-18-2009, 04:20 PM   #9
texastruckjunky
Yea what 72 custom camper said it's totally different the bracket that he will need goes inline with the shifter on the frame, and it boltes to the inside of the frame.
