Old 08-17-2009, 04:19 PM   #1
Silence86
Silence86's Avatar
Exclamation window question.
ok so on my 86 i went from power windows to no windows at all....i had to change the whole electrical system....i wanna change my windows to the manual windows...what all do i need? and can i use the same doors?
Silence86 is offline   Reply With Quote
Old 08-17-2009, 04:38 PM   #2
Jonboy
Slots go on anything!
Re: window question.
You can use the same doors, but you will need manual regulators from 77-up. The glass and everything else is the same. I don't know where the window crank handle will end up in relation to the hole in your door panel, though.
Old 08-17-2009, 05:03 PM   #3
Silence86
Silence86's Avatar
and i have another pair of doors that are rusted but have all the components inside and it was all manual...it was an 83. i can switch from door to door right?
Old 08-17-2009, 06:17 PM   #4
Jonboy
Yep.
Old 08-17-2009, 08:26 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
I did the swap last year it was easy
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
