Aux Trans Cooler Question
Can a relatively small auxiliary trans cooler (about 6 inches by 12 inches) cool an automatic tranny by itself without the simultaneous use of the in radiator fluid cooler? Vehicle is light, will not tow anything and no racing around. Trans fluid will pass through cooler four times before going back to the tranny.
Re: Aux Trans Cooler Question
have seen this one used a few times on the board. 68shortstep has used it on at least 2 builds and he has had great results from hanging it on the frame under the passenger seat direct to the transmission. this is the route i plan to take. pic.......................
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
forgot pic...
this is what I used.....b&m front mounted
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Restoration Virgin!
Hey Al,
I like that!!...so is it just mounted to the rad support??...Also, is it routed through the tranny cooler in the rad too??...If not, could you route it that way??...What additional plumbing will it take? Thanks
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
heres another, listed as 5 x 12. summit has a multitude of coolers that are stand alone, and many that are made for towing that'll fit in a 6 x 12 space.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project Last edited by lofly'a; 08-18-2009 at 07:26 AM. |
#7 | |
-------------------------------------------------------------------------------- Last edited by gator2511; 08-18-2009 at 08:25 AM. |
Geoff It is NOT connected to the radiator at all, I ran the lines to the tranny and back to the cooler. I used high pressure hydraulic hose with anm fittings on both the cooler and the tranny. IT is bolted to the front of the radiator support and so far almost a year later no leaks or issues at all.
#9 | |
Restoring it $200 at a time...
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
Mine looks like that Summit 5x12 cooler. So, am I ok to run just the small 5x12 cooler all by itself with no small fan hooked up to it? I don't want to fry my trans fluid.
IMO, you'd be fine without a fan if you can get the aux cooler mounted in front of the rad. The only reason the GN has a fan is b/c the cooler is tucked up behind the air dam, where it wouldn't get much natural air flow.
#12 | |
18 Till I Die
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#13 |
![]() Join Date: Dec 2006
I would run it through the radiator after the cooler if you plan to ever tow or use your truck hard.
Also,don't just tie it up to the radiator with the supplied zip-tie things. It should be mounted securely on it's own. There are other opinions on this I know. The above reqs come from experience as a former employee (27 years ago) of a major transmission shop chain. edit; I just read your post again about light useage. I'd still go through the rad.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 08-18-2009 at 04:09 PM. |
#14 | |
There is Zero Vibration and it is mounted solid. My truck shakes alot because of the built motor but the cooler is there solid.
#15 | |
#16 |
here's what i believe, and also others on the board have agreed based on a previous discussions and our experiences. your engine operates at 180 degrees "nominally", and flowing transmission fluid thru 180 degree water is not an added benefit unless your transmission has already overheated, then the engines radiator will cool the fluid to whatever the engines temp is at that point which is usually too late to prevent some degree of damage. a stand alone unit, and/or one with it's own cooling fan is far better than cooling tubes routed thru the engines radiator side tanks. the factory setup is fine if you are not towing or hauling much, but the design is not the best setup that your transmission can have to perform and survive, especially in my part of the country.......JMHO.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project Last edited by lofly'a; 08-18-2009 at 04:55 PM. |
#17 |
Lofly'a,yeah that makes sense and I don'tremember their rational about going through the rad after the cooler but I think that maybe it was that the trans is designed to operate at a given temp.The viscosity of the ATF is set for a certain range of temps.
During a hard pull with full throttle shifts the fluid will be leaving the trans at greater than 300 degrees.I think the plan was to knock the temp down so that it wouldn't impart too much heat to the radiator coolant,possibly contribuiting to an overheated engine. And when you were not at the extreme heat levels,then the radiator temp would ensure that the fluid was within design temps.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
#18 |
I would also suggest that you invest in a tranny temp. gauge. Thats the best way to see whats going on with your cooling. If I lived up north I'd run the tranny cooling lines through the radiator to help it warm up on cold days but down here its not required and lets the radiator cool the motor and the aux. cooler cool the tranny.
#19 |
your insight makes a lot of sense also longhorn, sometimes i love this place and the knowledge to be gained and shared here.
#20 |
My engine does run a little too warm for me. Maybe if I run the trans fluid through the auxiliary cooler only I can drop the engine temp a little? That would be awesome.
#21 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Im throwin a small single pass aluminum one on my v-8 powered yota so thats what I tell ya to do..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
