Old 08-18-2009, 12:39 AM   #1
cobinder
Everything is work in progress
cobinder's Avatar
K20 Power steering pump
Can anybody tell me what pump came stock in my 80 GMC K20?
I think it's a Saginaw P series, are all P series the same, except for the bigger reservoir?
I'm looking for a stock replacement with res in chrome.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 08-18-2009, 11:34 AM   #2
cobinder
cobinder's Avatar
Re: K20 Power steering pump
Whats the difference between the vac booster pump and the hydro boost pump?
04 Honda CRF "500"
Old 08-18-2009, 07:48 PM   #3
ghettoluxury
ghettoluxury's Avatar
An extra hole for hydro boost line
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 08-18-2009, 10:38 PM   #4
cobinder
cobinder's Avatar
So the actual pump is the same.
04 Honda CRF "500"
Old 08-19-2009, 07:20 AM   #5
duallyjams
duallyjams's Avatar
I believe the pressure is different on a hydro pump.The valve can be changed from one pump to another.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-19-2009, 09:54 PM   #6
ghettoluxury
I am running hydro boost with a vac pump just put a tee in the line to run the extra one I will take pictures if you would like
Old 08-20-2009, 11:34 AM   #7
cobinder
cobinder's Avatar
Ghetto, Ive seen that done. But your using your stock non-hydroboost pump right? And it works fine.
04 Honda CRF "500"
Old 08-20-2009, 07:41 PM   #8
ghettoluxury
correct and the truck stops on a dime with four wheel Discs
