Loving the Jimmster
Starter wires?/
Ok Looking from the front of the truck so the drivers side is on the right! There are to small post on the starter selinoid(spelling?) I know that there is yellow wire and a purple wire. What one goes were???????
Thanks vance |
Re: Starter wires?/
The purple goes on the S post closest to the block and the yellow goes on the R post on the outside.
The yellow is the resistor bypass wire that gives a full 12 V to the coil when cranking and isn't needed if you have converted to HEI. Last edited by mr48chev; 08-18-2009 at 12:07 PM. |
Loving the Jimmster
Re: Starter wires?/
cool there right, now next question when you sitting in side the truck and try to start it what way should the fan turn?? Counter clockwise?????
