trailing arm crossmember?
If I am going to do a 5" + drop in the rear do I need a trailing arm crossmember? I have a 66 longbed with split drive shaft. ECE says theirs is for shortbed with single drive shaft.
#2 | |
Re: trailing arm crossmember?
The aftermarket units are typically for swb trucks but could be used on a lwb truck. Porterbuilts has provisions for a carrier bearing so it might be worth checking w/him on compatability.
VA72C10
![]() Join Date: Mar 2008
People also do them a lot for exhaust clearance on lowered trucks...allowing you to run your exhaust through your crossmember...I am going to do that with the factory crossmember by welding in round pipe.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Ahh I see. Thanks for the replys guys!!
