Loving the Jimmster
She runs!!!!!!!!!!!!!!!!
Well i was 180 out but all is good, she fired right up and runs very well. The starter is sticking a little so i am going to change out the selinoid(spelling) and start putting her back together THANKS A BUNCH FOR ALL THE HELP!!!
There is no way i could have done it with out all you guys Vance |
Tot Roddin'
Re: She runs!!!!!!!!!!!!!!!!
Glad to hear you got things buttoned up, now were are those pics?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Loving the Jimmster
There coming very soon. I have to re run all the wires and clean things up, i just ran everything to see if she would fire. Day or two and shell be back together
A sticking starter? Could it be that the starter needs a shim or two to stop the sticking? A bad solenoid would not cause sticking.
Loving the Jimmster
It keeps cranking when you shut off the key, i already replaced the key switch and its still doing it. not all the time but enough. Does that make sense?? I figure it has to be the selenoid??
I agree. Shim the starter before you replace parts.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Loving the Jimmster
Why would shims help it from staying engaged??/
The faster motion/turning of the flexplate/flywheel actually forces the pinion gear in the starter to disengage from the flywheel/flexplate teeth. Has nothing to do with the ignition switch or the solenoid. If the starter pinion gear is too close to the flywheel/flexplate ring gear teeth, the pinion gear will bind and not disengage.
