Old 08-18-2009, 02:53 PM   #1
novafrog
novafrog's Avatar
mildew trouble
what can i do to stop mildew,garage dry,cars dry,but after awhile they start to mildew
novafrog is offline   Reply With Quote
Old 08-18-2009, 04:08 PM   #2
big_al_71
big_al_71's Avatar
Re: mildew trouble
To reduce moisture and prevent mold buildup install a dehumidifier in your garage!!!!.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-18-2009, 04:12 PM   #3
mclairmo
Re: mildew trouble
Do you have moisture coming up through the slab? Maybe try and epoxy coating on the garage floor? Also, make sure you have vents going to outside to allow airflow. You don't want that garage hermetically sealed, will cause fungus, mildew, etc.
mclairmo is offline   Reply With Quote
Old 08-18-2009, 06:57 PM   #4
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Re: mildew trouble
X 2 !!!
Mold / mildew needs moisture to grow.
Dry the humid air = mold is stopped. Rust is slowed / stopped, too.
68shortstep is offline   Reply With Quote
Old 08-18-2009, 08:54 PM   #5
red71c10
The Red Menace
red71c10's Avatar
Re: mildew trouble
X2. It can't be as dry as you think it is if you're getting mildew.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 08-19-2009, 02:30 PM   #6
mclairmo
Re: mildew trouble
A dehumidifier will drive your electric bill sky high, though.
Old 08-19-2009, 03:43 PM   #7
don t. - 72gmc
Re: mildew trouble
If the mildew is on the inside of the truck, you could use....
.....a plastic tub with some BBQ charcoal
.....a buncha silica gel packets.
.....a glass container with salt spread on the bottom
Refresh as needed, when needed.
HTH....good luck.....don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 08-19-2009, 10:34 PM   #8
novafrog
novafrog's Avatar
Re: mildew trouble
yes thats where it is on the inside,thanks i will try this
