Old 08-18-2009, 08:00 PM   #1
flemingb
Neutral Safety Switch
I have a 1984 Chevy K20 that the neutral safety switch went on the fritz. Its a manual. Needless to say the hook on the end of the switch broke thus starting the saga of finding a new switch. When we took the metal cover off to expose the area with the switch it was just dangling there. I found a new switch from collectors auto supply and ordered 2 plastic bolts part # 336250 and the bracket part # 336251 with the switch well just the switch came and they were having problems with the supplier that the switch came from so they found 2 bolts and they are on their way. Does anyone know of where you can get the bracket they call it Bracket,Clutch Neutral Start Switch and the original part number is 336251 as stated above? Are these all the pieces required to put the new switch back where it goes to keep it stationary or is another part needed? The truck is due for inspection in the end of September and kind of need to have it fixed.
flemingb is offline   Reply With Quote
