08-18-2009, 08:45 PM | #1 |
1965 GMC "Bessie" build thread
Ok, finally decided to put a build thread together. I have been hanging around for some time posting a few times but mostly just studying and learning.
This is my 65 GMC short bed fleet BBW. I bought it about 4 years ago. I wanted something cool to drive daily while I worked on my 55 1st series truck. The truck sat for about 10 years when I got it…. Motor ran , no brakes, needed some TLC. The build was quick and dirty to get it on the road as cheap as possible. Here is what she looked like for about 2 years
Jared USMC 1st Battalion 8th Marines (95-99) 55 1st Series 3100 (on 98 sonoma frame) 65 GMC short bed fleetside big back window http://67-72chevytrucks.com/vboard/s...d.php?t=358493 |
08-18-2009, 08:48 PM | #2 |
Re: 1965 GMC "Bessie" build thread
Bessie ran great, had a few minor instances where she got upset. Negative battery cable melted and shut her down, wheel fell off (not one of my finer moments…check out the carnage pic) and the shift linkage on the tree broke several times. I had a TH350 that I was going to use on my 55 so I decided to rid myself of the 3 on the tree. Well one thing led to another and next thing I knew Bessie was in a few hundred pieces.
This is rebuild #2 and I am tying up all the loose ends, doing things right and fixing the shortcuts I did the 1st time around. The theme is a mid sixties custom. I have installed the front suspension from an 87 burb… also got the power master cylinder and steering box from the same vehicle. [ATTACH][/ATTACH]
Jared USMC 1st Battalion 8th Marines (95-99) 55 1st Series 3100 (on 98 sonoma frame) 65 GMC short bed fleetside big back window http://67-72chevytrucks.com/vboard/s...d.php?t=358493 Last edited by 1stseries55; 08-23-2009 at 03:59 PM. |
08-18-2009, 08:51 PM | #3 |
2.5” spindles and 3” coils ….she is low…. After recommendations from you guys and got rid of the bumpstop mounts The rear end is also from the 87 burb (wanted 5 lugs all the way around)…. Flipped it above the leafs and added a c-notch.
08-18-2009, 08:53 PM | #4 |
nice truck
1965 gmc |
08-18-2009, 08:54 PM | #5 |
Right now I am working on finishing the rest of the suspension…need to work out pinion angles and run fuel/brake lines, paint…..etc…. As far as body work, she is going to be a flat metallic blue with a gloss white roof. Adding 59 caddy taillights …
08-18-2009, 08:58 PM | #6 |
Going with black steelies this time… I powder coated these with my eastwood home powder coat system… they turned out awesome. I started powder coating a bunch of stuff…
Here are my el-cheepo headers w/ high heat PC … hopefully that does not burn off as fast as the “high heat” paint did. Thanks for all the good advice folks……
08-18-2009, 09:14 PM | #7 |
Resistance is Futile
Nice job 1stseries. Truck looks good. My '64 is running the same set-up suspension-wise. It rides nicely and Ive only bottomed out twice; once due to hitting a speed bump too fast. You can 'overcrank' the steering with those stops removed, you'll know when you do.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-18-2009, 09:21 PM | #8 |
Nice clean work! I'm impressed!
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
08-18-2009, 09:23 PM | #9 |
thanks protrash....did you have to move the rear back to compensate for the drop? or shorten the drive shaft?
08-18-2009, 10:13 PM | #10 |
I wish my front end looked that clean.
Nice work... can't wait to see the finished product. |
08-18-2009, 10:19 PM | #11 |
Very nice build man. Looks killer.
08-18-2009, 10:33 PM | #12 |
nice work!!
CHEVY ONLY |
08-18-2009, 10:51 PM | #13 |
No I didnt, but to qualify, I replaced the whole drivetrain at once so I didnt know where anything was supposed to be anyway. Used front engine mount location, aftermarket trans x-member, had the driveshaft redone cuz everything else was being redone too. My truck was such a mutt that I dont know if the driveshaft was original or not.
08-18-2009, 10:52 PM | #14 |
1 thing at a time is progress.
Glad to see you posting about your build. I've noticed you hang out over here alot. Welcome to this side. Nice work so far. I thought about putting the 59 caddy lights on mine, it's somewhere in my post, but got sidetracked with it for now. If I do mine I want them recessed more in the corner. It's hard for me to give you a visual. Your lights look great. Nice progress. I'll be Lookin' for more progress in the furure.
Alan
Philippians 2:14-16 |
08-18-2009, 11:27 PM | #15 |
Just here to tinker
I dig it! Love the stance. Stance can make or break a truck. You nailed it!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
08-18-2009, 11:41 PM | #16 |
Hollister, CA.
Sweet man...look'n sick !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-18-2009, 11:52 PM | #17 |
60-66 Nut
Looks good....nice work
08-19-2009, 12:18 AM | #18 |
Super nice, one of the best years too. 64-66 bbw swb trucks rule! Dont let anyone tell you different (if they disagree they dont know sh!t).
08-19-2009, 07:21 AM | #19 |
Registerd User
I agree with everyone. Nice lookin truck.
08-19-2009, 07:44 AM | #20 |
sweet build up. wish I hadn't gotten rid of my 65.. keep us updated on progress for those of us without progress lol
08-19-2009, 11:56 AM | #21 |
Sweet truck man looks real clean/rust free too.
Keep the pics comin! |
08-21-2009, 03:20 PM | #22 |
the flames really top off the old school look!
08-21-2009, 07:44 PM | #23 |
thanks for all the kind words fellas...
should have some updates by the end of the weekend. I have a soft spot for old school flame jobs... this time around the roof will be white... I plan on adding some flames to the top of the roof in the main body color (flat blue metallic)
08-21-2009, 08:20 PM | #24 |
Garage wrench
flat blue metallic? Sounds cool, can't wait to see it. I've been wanting one of these mid 60's GMC's a lot lately, they're sweet.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
08-22-2009, 01:45 PM | #25 |
it's called diamond blue metallic.... Hot Rod Flatz brand....
i have a gallon of the stuff....just need to get my a$$ in gear and get this thing finished.
