Old 08-18-2009, 08:54 PM   #1
texas56
texas56's Avatar
Thiftmaster S10 build
We have been workin on this truck on and off for the last few years. When we get caught up we piddle with it. Blown 355 under the hood,TH400, Air ride, 4 wheel disc brakes, 4 linked rear, 20s and 22s. In the interior we are going with a modified 57 Chevy Car dash, Custom sheet metal in the engine compartment. This s10 conversion has been a big challange to get the gaps right. Right now we are boxing in the frame and welding it up. Hope to be spraying some paint soon! We have changed up a bunch of it so some pics are old
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 08-18-2009, 08:59 PM   #2
texas56
texas56's Avatar
Re: Thiftmaster S10 build
more
Old 08-18-2009, 09:02 PM   #3
texas56
texas56's Avatar
j
Old 08-19-2009, 12:33 AM   #4
50adrod
50adrod's Avatar
nice looking truck
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 08-19-2009, 05:55 PM   #5
IL boy
IL boy's Avatar
man this is a sweet truck. why did u change the grill? i love the look of the 54 and 55 1st. i hope when im done with my 55 1st it turns out as nice as yours.. with a different grill that is
55 1st Series 5 window, getting an s10 frame and 350 sbc
Keeping it LOUD and ROUGH - just like BOONEMAN
IL boy is offline   Reply With Quote
Old 08-19-2009, 06:11 PM   #6
fiddy9apache
fiddy9apache's Avatar
dam thats nice
fiddy9apache is offline   Reply With Quote
Old 08-19-2009, 09:25 PM   #7
texas56
texas56's Avatar
thanks guys! When I started the project I couldnt find the 54 and 5 grill aftermarket so I went other route and bought the new one.
Old 08-19-2009, 10:34 PM   #8
BlueJeep
BlueJeep's Avatar
Can you post more pictures of your radiator support? How did you mount your running boards? Great looking truck!!!!!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 08-20-2009, 04:13 AM   #9
steve53
steve53's Avatar
hell yeah man nice look. you hit the nail on the head! what wheels are you using and where did that dash come from?
edit:
oh just saw the post again and got the dash info... posting while drunk for the win!
53 Chevy 3100 1/2 ton
1st Armored Division, OIF Veteran
steve53 is offline   Reply With Quote
Old 08-20-2009, 07:17 AM   #10
63 & 64 Bowties
and a few others
Wow. Just wow. What else can I say?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-20-2009, 01:56 PM   #11
outlawc
Can you give me some chassis info please, like which S10 chassis are you using, 1st or 2nd generation and will the wheels turn lock to lock aired out?
outlawc is offline   Reply With Quote
Old 08-21-2009, 01:08 PM   #12
texas56
texas56's Avatar
Im using a S10 extended car early 80s. As far as more pics, sure Ill try and get you some but the truck is apart right now trying to get ready for paint.The running board brckets have been the hardest part due to trying to get them to make all the sheetmetal line up correctly. But I think and hope we have it now. As far as core support that was another challange due to the whole front end pretty much using it to mount up.Im a firm beleiver that if was ever to do it again, we would use the s10 but only if building a rat rod. Been way to much work for it to have paint. Ill get some core support pics this weekend and running board mount pics.The instrument cluster is a 57 chevy car but the rest is built from scratch! thanks for all the complients!
Old 08-22-2009, 01:00 PM   #13
outlawc
Thanks texas56 for the info. If you dont mind me asking, how much of a turning radius do you have with the bags deflated?
Old 08-22-2009, 07:03 PM   #14
Lextech
Lextech's Avatar
Did you change the front fenders or are they the 54-55 1st?
Jeff
Lextech is offline   Reply With Quote
Old 08-24-2009, 09:53 AM   #15
texas56
texas56's Avatar
I changed the front fenders as well. If the grill would have been avail. when I started I would have kept the 54 -55 front just because it was different.
I need to check the turning radius again once assemebled. I think I will have to have it aired up a lil more when turning sharp now. I put bigger brakes on it and Tubular A Arms and it pused the wheel out a lil farther. When I had the stock S10 stuff on it, the thing would turn very good with the bumper about a 1 inch off the ground. I think I lost a little bit though now that the tire is out a little farther. Im runnin a 20x8.5 on the front with a 255/35/20 tire. I could possibly run a narrower tire down the road. I ran a 305/40/22 on the rear and still have a ton of room. Will prolly go with a 325 tire if and When I burn these off! HEHE
Old 09-01-2009, 09:44 AM   #16
texas56
texas56's Avatar
Got some more frame work and firewall work done this past weekend. Gettin closer and closer. IT has been a real chore boxing in this frame. All we have left now is to add the cross braces and finish up the weld out and ground down of the runnin board mounts. We are going to also add some more cosmetics to the frame. We are getting there though!
Old 09-01-2009, 09:47 AM   #17
texas56
texas56's Avatar
Motor Mock up. Blower will be under the hood.
Old 09-01-2009, 10:04 AM   #18
Hart_Rod
Hart_Rod's Avatar
That's nice....
Hart_Rod is offline   Reply With Quote
Old 09-01-2009, 10:43 AM   #19
BlueJeep
BlueJeep's Avatar
Thanks for the additional pics!
Did you section the original running board mounts to fit them on the wider frame? Kinda looks like you did to retain the original rivet flange up against the frame but I wan't sure.
Nice work!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-01-2009, 11:02 AM   #20
texas56
texas56's Avatar
ya we had to section and shortin them a lil. Been so long ago I cant remember though how much. Was a pain.
Old 09-01-2009, 10:31 PM   #21
eventytoo
Wow looking good. I feel the same way.....the s-10 rute is way to much work for paint. Mine would be in paint by now if it wasnt for the s 10 idea. I like the 20/ 22 combo.
eventytoo is offline   Reply With Quote
Old 09-02-2009, 08:56 AM   #22
c10addict
c10addict's Avatar
Freakin love it!!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 09-04-2009, 11:54 AM   #23
texas56
texas56's Avatar
thanks guys. Got all the Sheetmetal in Primer now and hope to start laying some paint down in next several days. Lack about 2 days of chassis welding then we can prep it and paint it as well.
Old 09-08-2009, 11:24 AM   #24
texas56
texas56's Avatar
More progress..........
Old 09-08-2009, 11:50 AM   #25
texas56
texas56's Avatar
Flippin it over
