oppions needed
i want to build a 67-72 4x4 truck
What would be cheaper buy a 2wd truck and put it on a 4x4 chassis 0r keep looking for a complete 4x4 truck
1968 Chevy C10 6/8 drop ( great grandpas truck) under construction 1972 Ford Bronco project 2006 chevy Silverado 2500hd dd 1995 k2500 solid axles 12v cummins crew cab ![]() Last edited by DuramaxC10; 08-18-2009 at 09:28 PM. |
its all about the +6 inches
Re: oppions needed
depending on how much work you want to do... if you are a fab man, then all you need is a body.
But if you are the average dude, hold out for a truck with 4X4 under it already. |
Re: oppions needed
find a 4x4 to begin with
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: oppions needed
X2. I just passed one up for $900. You can find them.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Re: oppions needed
start with a 4x4 truck trust me ..
if you start with a 2wd truck and buy the 4x4 parts you'll probably have more in it than if you started with a 4x4 to begin with the you still have to make it all work Last edited by NUTS4TRUCKS; 08-18-2009 at 11:15 PM. |
Re: oppions needed
I guess it all depends on what the truck or trucks cost.Most body swaps are done because they found a 4wd with a poor body for cheap then found a 2wd with a nice body.I don`t think these swaps would have happened if the prices were high on either truck.It was done because it was cheaper than buying a real nice 4wd.I think it all starts with finding the perect match or you are best to find a 4wd.It`s definately less work.
Re: oppions needed
Buy a factory 4x4.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: oppions needed
I agree...... Buy a factory 4x4 money ahead..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
more ideas than money
Re: oppions needed
As someone who builds off road only vehicles, just buy a 4x4. There are just so many things like trans tunnel, extra crossmembers, proper axle alignment, steering geometry, changing the trans from 2wd to 4wd, tranfercase, shifter location/fabrication, etc. It is alot of work to do to compensate for a slight difference in purchase price.
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
#10 | |
Re: oppions needed
Re: oppions needed
There are a couple of 67 4x4 on craigslist? PostingID: 1328118665 & 1311402696.
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI. |
Re: oppions needed
could you send the links
1968 Chevy C10 6/8 drop ( great grandpas truck) under construction 1972 Ford Bronco project 2006 chevy Silverado 2500hd dd 1995 k2500 solid axles 12v cummins crew cab ![]() |
#13 |
Re: oppions needed
Here is the link to "craigslist" through out the USA. Just type in the post # in the search box.
http://www.searchallcraigs.com/resul...sa=Search#2609 PostingID: 1328118665 & 1311402696 Howard
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI. Last edited by howard_m18; 08-20-2009 at 03:59 PM. |
