08-18-2009, 10:38 PM | #1 |
eaton posi rebuild question
anybody know how to replace the clutch discs and springs in a eaton posi diff. ? i have it out of the axle and i got my spring and clutch pack kits . now its time to get to it. anybody done this before ?
bob
I BELIEVE IN JOHN 3:16 |
08-18-2009, 11:01 PM | #2 |
Re: eaton posi rebuild question
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-18-2009, 11:06 PM | #3 |
vettes have dana 44,s in them
08-18-2009, 11:38 PM | #4 |
My Carbon Footprint
Awe man....I don't know if I can find the link or not. There is a guy on Team Camaro that walked me through it and he had some great techniques. On was to bolt the loose axle to the wheel on the floor so the spines are sticking straight up and use that to roll the side gears into place as you hold the carrier. You can get the clutch pack good and tight. I think the trick is to make sure the side gears are really snug against the spider gears. All I know is my Eaton is darn near like a spool with zero noise and serious black marks. I will look for it.
08-18-2009, 11:44 PM | #5 |
thanks
08-18-2009, 11:59 PM | #6 |
My Carbon Footprint
Okay.....found it! The first part is a little blah, blah, blah, but it give you an idea of what I started with. The next link is having "big gear head" (freddie) explain how to get the clutch pack tight using the axle spline while bolted to a wheel on the floor. This guys is the sheet on Team Camaro when it comes to diffs. Hopefully it will make sense to you. I had ever done anything like that at that time and it worked perfect!!!
http://www.camaros.net/forums/showth...ht=clutch+pack http://www.camaros.net/forums/showth...ht=clutch+pack |
08-19-2009, 09:59 PM | #7 |
thanks but theres really no instructions on those links just tips. still looking
08-20-2009, 04:20 PM | #8 |
What?
Not sure about the year, but thought this might help you.
The link and document say Dana, but they cover Eaton posi rebuild in it. http://www2.dana.com/pdf/AXSM-0047.pdf
Chris 1968 K20 Suburban 1972 K10 LWB PU |
