08-19-2009, 12:17 PM | #1 |
67cheby
ls1 fuel pump problems, suggestions
my friend is running a 1999 model ls1 in his 68 he is still running the factory tank with a inline fuel pump , he cant seem to get it regulated right , any suggestions certain pump to run or could it be the plumbing, anyone else running the factory tank.. i am sure a tank with the built in fuel tank would be the best bet but he has little extra money .. just trying to do it on the cheap. thanks mike
08-19-2009, 12:18 PM | #2 |
Re: ls1 fuel pump problems, suggestions
What kind of fuel pump is he running?
08-19-2009, 02:10 PM | #3 |
powdercoater
Did he add a return line ?
should have atleast 45psi at the rail,maybe the inline pump is not for a inj eng ?? scott |
08-19-2009, 02:18 PM | #4 |
the regulation is done at the fuel rails on that year. I acutally run around 52 psi on my puel pressure at idle. You will need a return line and should check the pressure let us know what you mean that it wont regulate what are his pressures.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-19-2009, 03:27 PM | #5 |
67cheby
thanks for all of the suggestions so far i will try to find out some more of the specifics ie.. return line and pressures
08-19-2009, 04:18 PM | #6 |
The Older Generation
I'm not familiar with the ls1 but I bought a book on TPI installations and the guy that wrote it recommends a 78-81 Nissan/Datsun 280ZX external pump. Advance Auto Parts online # is E8312. When I looked it was $107.98. He says you can put a "T" fitting in the intake side of the pump and just run the return line to it. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-19-2009 at 04:20 PM. |
