Old 08-19-2009, 03:58 PM   #1
67cheby
67cheby
67cheby's Avatar
140 amp alt , 2 air zenith comp , 1 battery
running a 1 wire 140 amp alt , with 2 air zenith compressors,air ride ride control, a stereo system (2 amps, 2 12s) will i be able to do this with one battery, if so any battery suggestions
67cheby is offline   Reply With Quote
Old 08-19-2009, 11:30 PM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: 140 amp alt , 2 air zenith comp , 1 battery
As has been mentioned before on this board, the battery does not run the accessories when you are driving, the alternator does. However, I would think that a 140 amp alternator would be plenty strong enough to run the stuff you mentioned. Remember that your stereo is not a constant load (Like your compressors are) but a dynamic load. Some car stereo guys put in 1 Farad capacitors in parallel with the 12 volt supply to their amps for just that reason. If you are still concerned, buy a real heavy duty Group 24F battery in the 700 to 1,000 CCA range but I really don't think IMHO that you need to go through all the hassle that installing a second battery entails. BTW, 1 wire alternators have the problem of not charging very well at low RPMs. I hope that doesn't cause you any problems down the road.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
