Old 01-11-2003, 04:32 PM   #1
Slick71
Slick71's Avatar
73-87 axles vs. 67-72
I'm thinking of putting in some complete 3/4 ton axles from a 73-87 4X4, I currently have 3:08 gears in 1/2 ton axles. Are the spring pads wider on the 73-87 than the 67-72? How much work would need to be done to make this work? Would I also need to change U-joints, etc? Thanks!
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 01-11-2003, 04:44 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Front axle is a direct bolt in. The rear will require moving the shock mounts, I believe. You would have to get hybrid type u-joints or replace the yokes on your TC. Do a search here and over at www.coloradok5.com to get more info.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-11-2003, 04:48 PM   #3
6772king
6772king's Avatar
the front is a bolt in, the distance between the perches is a little more but will still work the back the shock mounts need to be changed and I cant remember if the spring perches are the same or not.
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 01-11-2003, 06:51 PM   #4
Mudder
Mudder's Avatar
You know I can't remember for the life of me what I have in my truck (ujoints) and I really need to change that thing. At times I really think that my ujoints are the same as a half ton front and rear. 77 chassis 3/4 ton
Mudder is offline   Reply With Quote
Old 01-14-2003, 09:51 PM   #5
BobS
BobS's Avatar
Spring perches on the rear will need to be moved also. 73-87 are 4-5 inches wider if my memory is correct. One tons from the later years have their springs at the same width as 67-72 but shock mounts are different.
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
