Old 08-19-2009, 06:47 PM   #1
Eichorst69
69-72 rear wheel studs
I am converting my 69 C20 4x4 with the Eaton rear end to rear disk brakes and I need to drill out the hubs to swap the 1/2'' studs to the 9/16 studs.
The question I have is, what size drill bit do I use so the studs will fit properly in the hub? Has anyone done this before? Any tips will help.
Thanks, Rob
Eichorst69 is offline   Reply With Quote
Old 08-19-2009, 07:38 PM   #2
cdowns
cdowns's Avatar
Re: 69-72 rear wheel studs
i'd buy couple extra studs and practice on a piece of scrap metal// that's about as exact as i can figur
Old 08-19-2009, 07:43 PM   #3
71swb4x4
71swb4x4's Avatar
Common sense would tell me that you need to make the hole 1/16" larger than it was before. Figure out how big the hole currently is, and drill it out another 16th of an inch. That being said, common sense for me doesn't come easily, so don't take my word for it!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
