Old 08-19-2009, 06:48 PM   #1
shilo
shilo's Avatar
Rear end options?
Ok, for my 71. My engine (496) is sitting on the dyno waiting for a carb. then it will be ready. I just got my 400 and 205 put together. Again ready to go in.
Currently i have a big hub dana 44 front which measures about 70" wms. I have a 14 bolt rear in it but dont know how wide it is. Both 4.10
Today i traded a 454 for a Dana 60 front and dana 70 rear. 4.10 gears. Dually.
I need single wheel hubs for the front. I know this. Then im guessing it will measure out to 70". any body confirm this?
Question of the day is should i mess with the D70 or just leave the 14 bolt in?
The D70 measures 73"
Widths, widths widths...anybody got ideas what would look cool?
I wouldnt really gain anything strenghtwise, but its an option and when i have options i tend to over think them!
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 08-19-2009, 06:56 PM   #2
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Rear end options?
Ive heard ( meaning I dont know from experience, but have been told by some people I trust) that the 14 bolt is nearly as strong if not stronger (in some respects) than the 70 and WAY easier to work on.. Parts are everywhere for the 14bolt as well.. I guess the benifits of the 70 would be strength and ground clearance.. I hear gearing selection is something to weigh as well. Hope this helps. There is a ton more of info on pirate4x4 regarding the d70 vs 14bff..
Eturnit3 is offline   Reply With Quote
Old 08-19-2009, 07:39 PM   #3
duallyjams
duallyjams's Avatar
If you run H1 wheels you can run the bud wheel hubs on the front.Just a thought.
14b is plenty strong enough out back.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-20-2009, 02:41 AM   #4
shilo
shilo's Avatar
I understand that d70s and 14bolts are comparativaly in strength. I have a narowed 14 bolt with a spool in my jeep. I was just having an option to change around width and was wondering if anybody had a suggustion.
Old 08-22-2009, 08:40 PM   #5
justcuz
justcuz's Avatar
You can just unbolt the dually hub extensions from the front and change wheel studs if I remember correctly. You can narrow the dually rear axle with single rear wheel hubs. Ford had some SRW dana 70's I think or Dodge diesel hubs and brakes.
justcuz is offline   Reply With Quote
Old 08-23-2009, 12:32 AM   #6
skchevota
skchevota's Avatar
alot of people want the wider rear, it will make you rear tires stick out an inch or so more than the front, if you keep your 14 bolt it will be the oppisite. You 14 bolt will have a width of about 67" if it is a single wheel axle.
skchevota is offline   Reply With Quote
Old 08-23-2009, 07:24 AM   #7
ghettoluxury
ghettoluxury's Avatar
If you are going to put single wheel hubs on the Dana 60 than I would keep the 14 bolt so that the tires sit the same place they are now. If you were talkin a dually conversion than thats another story.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 08-25-2009, 07:53 PM   #8
shilo
shilo's Avatar
What do yal think the truck would look like if i put the wider D70 in? Seems ill be about 3 inches wider on each side
Old 08-25-2009, 08:34 PM   #9
ghettoluxury
like something was off
Old 08-26-2009, 11:10 AM   #10
shilo
shilo's Avatar
haha. Yeah, thats what i figured.
