Old 08-19-2009, 07:03 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Throttle Cable Problem
72 c-10 with a 350 and edelbrock carb.
Ok... so the original throttle cable broke on me, so I ordered one from LMC. When I got it, it went in no problem...
BUT
Where the original cable kinda did this "S" turn thing to go from the firewall to the carb, the new cable does not. It does a giant "C", and where it connect to either the carb, or the firewall, it is at a horrible angle, cause the throttle cable to stick when pushing on the gas (but not when letting off... )
I tried zip tying a think piece of 1 gauge electrical wire to the throttle cable to force it into the "S" curve, but it's not working too well... and the throttle still sometimes sticks.
What can I do to fix this?
Is there a shorter cable maybe?
Who else hates it when stuff that is supposed to work, doesn't?
Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 08-19-2009, 07:09 PM   #2
mclairmo
Re: Throttle Cable Problem
Can you shorten that cable?
mclairmo is offline   Reply With Quote
Old 08-19-2009, 07:10 PM   #3
toddtheodd
toddtheodd's Avatar
I don't think so... it's not a universal one...
Or at least... I don't know how to shorten it.
I wonder how the hell the got the original one to do the "S" curve...
IIOY???
Old 08-19-2009, 07:17 PM   #4
mclairmo
I would study the cable and see if you can shorten it at either end without destroying it. Or, find a shorter one. Or, try a universal one such as a Lokar.
Old 08-19-2009, 07:28 PM   #5
toddtheodd
toddtheodd's Avatar
I'm looking at YearOne right now... and they have different ones for the K series and the C series (4x4 and 2x4)...
Does anybody know... are the K series cables longer than the C series???
IIOY???
Old 08-19-2009, 08:26 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
k series would be shorter, the engine is closer to the firewall
Old 08-19-2009, 08:50 PM   #7
toddtheodd
toddtheodd's Avatar
Hmmm... it's not too expensive from LMC... maybe I'll order a K series one and see if it's too short...
Thank you,
Toad
IIOY???
Old 08-20-2009, 06:52 AM   #8
gator2511
gator2511's Avatar
Talking Re: Throttle Cable Problem
I bought a throttle cable and fittings from Lokar and used that until I wore out the cable. Now I buy a replacement cable from Advance and trim the cable and sheath to fit and use the set screw lockar pieces to fasten the cable. I don't have an "S" in my cable. The Lokar piece is a little pricey but getting the cable to fit now is no problem. I used to carry a long piece of string in case the cable broke and sure enough one day it did. I tied the string to the carb linkage and ran it through the firewall and had a hand throttle to get me home. Now I carry an already cut to fit spare in the back.
gator2511 is offline   Reply With Quote
Old 08-20-2009, 01:24 PM   #9
mclairmo
With those kinds of problems with the cable breaking I would convert to the older style throttle rod. Never seen one of them break before.
Old 08-20-2009, 01:34 PM   #10
Longhorn Man
while you are right, a throttle cable is way safer, which is why they went to them. The rod will bind if/when the motor mount seperates... GM had a recall on this that included our trucks.
Plus, it is VERY rare to have a throttle cable go bad.
Old 08-21-2009, 06:58 AM   #11
gator2511
gator2511's Avatar
The main problem I had was the bracket was not lined up correctly. Since I fixed that I have had no problems but when you are miles back in the woods during hunting season you might want a spare just in case. I guess my main point was that you could get a good fit with the Lokar stuff.
Old 08-21-2009, 10:07 AM   #12
big_al_71
big_al_71's Avatar
+1 on using the lokar cables. I used everything I could from Lokar products oil dip stick, tranny dipstick, tranny shifter, throttle cable and I am super happy...If you look at this pict below you can see the throttle cable straight from the firewall no "S" or curves..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-21-2009, 11:07 AM   #13
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
GM intentionaly made the cables too long. Like when the linkage binds going to the carburetor when the motor lifts when the motor mount brakes, when the cable is too short it will pull the accelorator. Either way you will be in for a ride!! WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-21-2009, 04:59 PM   #14
toddtheodd
toddtheodd's Avatar
That's groovy and all... but how did GM get the bloody things in the "S" shape? Should I bend a 3 foot long one gauge cable into the correct shape, zip tie it to the throttle cable, and throw the whole bloody thing in the oven for 30 minutes at 300° and then throw it directly into the deep freeze after to see if that will... mold it into the correct shape?
Toad
IIOY???
Old 08-21-2009, 05:19 PM   #15
Classic Heartbeat
I don't believe they molded it. That was just the shape that the cable took after instalation. Any GM cable I have ever sold were strait to start with. I wouldn't toss the cable into the oven, you might just cause it to colapce around the cable. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 08-21-2009, 08:27 PM   #16
71 super
71 super's Avatar
How long is the cable LMC sold you? They are not generally very long to begin with. The 4x4 unit as Andy said is shorter as the motor sits much closer to the firewall. I have not got a cable that has a "s" curve in it. They may have a slight bend but nothing more than that and both of mine are GM units FOR these trucks, which were still available from GM as of last year. I don't have a part number handy for you to use but if no one else can get one I will check for you. LMC has a tendency use stuff that is "close enough".
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-23-2009, 03:21 PM   #17
toddtheodd
toddtheodd's Avatar
I think that is the problem. When LMC sent it to me, it was "curved" in the packaging. It's been a pain in my patooty to get it OUT of that shape now.
I will measure mine either tomorrow or the day after (after I kick this freakin flu), but I was wondering if anybody could tell me what the lengths are. For 350 2wd, 350 4wd, and 402?
That way I can compare and know which I have.
Todd
IIOY???
Old 09-23-2009, 03:37 PM   #18
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have only used lokar and love them...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-23-2009, 03:59 PM   #19
71tahoe
71tahoe's Avatar
My original cable got a little worn and when I swapped to a V8 it had to be replaced soon after. I mounted the new one and gave it a little twist so it was more like a corkscrew than an "S" and it worked great for 16 years then started to bind like you're describing.
I replaced it with a spectre from Autozone and it was OK. The cheapo plastic bushing pulled through the pedal because of my son's size 14s (and bull-in-a-china-closet mentality) but I put on a small steel washer and no more problems.
Then sold the truck so REALLY no more problems.
71tahoe is offline   Reply With Quote
Old 09-23-2009, 04:45 PM   #20
Alex Hayley
For those that have used the Lokar cable, the instructions say that an extra inch of cable housing should be added to the straight line distance from the firewall to the throttle mounting bracket. This will handle most normal engine movement. I realise that it is not possible to alter the length of the stock/factory cable housing but it should give you an idea of how much of an "S" or "C" should be in between the firewall and bracket.
Alex Hayley is offline   Reply With Quote
Old 09-23-2009, 07:07 PM   #21
rogergodding
rogergodding's Avatar
got one of the universal cables from Pepboys and it works great.
rogergodding is offline   Reply With Quote
Old 11-28-2009, 08:58 PM   #22
gmc1971harwich
gmc1971harwich's Avatar
i have the same problem im running a 67 327 and 700r4 in my 71 and at part throttle it sticks and i have to hit the gas harder for it to go faster
gmc1971harwich is offline   Reply With Quote
Old 11-29-2009, 04:30 PM   #23
toddtheodd
toddtheodd's Avatar
I would say that my "stock" cable from LMC is about 4 to 5 inches longer than the straight line from firewall to throttle mounting bracket.
IIOY???
