Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-19-2009, 09:52 PM   #1
Gene
Gene's Avatar
Rear swaybar setup off of 91 4x4 Burb $50
Bought a burb for the differentials and now I dont need them, it has an rear aftermarket sway bar w/polyurethane bushings.
50 Bucks plus the ride.
M.O. or cash accepted.
Fedex shipped.
Pics upon request
Gene is offline   Reply With Quote
Old 08-19-2009, 09:53 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Rear swaybar setup off of 91 4x4 Burb $50
im interested, pics?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-19-2009, 10:12 PM   #3
cochino12
It followed me home?
cochino12's Avatar
2nd in line, price shipped to 80134 thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-19-2009, 10:19 PM   #4
Gene
Gene's Avatar
This is the best pic I could get tonight. Will get better ones tomorrow when I take it off.
Old 08-20-2009, 04:16 PM   #5
Gene
Gene's Avatar
More pics, looks to be about 1 1/8 inch diameter sway bar.
Old 08-20-2009, 04:25 PM   #6
Gene
Gene's Avatar
59.62 shipped to 80134 Fedex Ground estimate
Old 08-20-2009, 06:19 PM   #7
Stitch
Location: Where I come from, it's cornbread and chicken...
put me next in line...shipped to 29151
thanks...Chuck.
Stitch is offline   Reply With Quote
Old 08-20-2009, 07:20 PM   #8
SBTork
Garage wrench
SBTork's Avatar
It does look like a decent piece but im out. Adam, your next in line.
-Adam
Old 08-21-2009, 05:26 PM   #9
Gene
Gene's Avatar
thanks...Chuck.
Chuck, looks like it's down to you. cochino passed because he has a 2wd truck. I'll get you a quote as soon as I find a box that the sway bar will fit in.
Old 08-21-2009, 07:04 PM   #10
Stitch
it's a rear sway bar so it should fit on a 2wd...that's what I have also...I just assumed it would fit....do we know for sure it won't fit on a 10 bolt?
Old 08-21-2009, 08:10 PM   #11
bigblock73
yeller
bigblock73's Avatar
Keep in mind Adam had a 70's Blazer (12 bolt), and a flip kit to boot. I doubt it would work for his application.
You also have to figure, if this is a bolt on for a 4wd truck, it might not bolt up to a 2wd truck...springs and ride height are different.
bigblock73 is offline   Reply With Quote
Old 08-21-2009, 08:20 PM   #12
JMac11
JMac11's Avatar
have an 84 4wd and would buy this ASAP
JMac11 is offline   Reply With Quote
Old 08-21-2009, 08:38 PM   #13
Gene
Gene's Avatar
Not really familiar with 2wd vs 4wd suburban frame differences? All I know is that the brackets mount directly to the frame, and if a 2wd is any wider or narrower than a 4wd it will not work. Experts??? BTW it was mounted on a 10 bolt.
Old 08-21-2009, 08:40 PM   #14
Gene
Gene's Avatar
If Fathoe can't use it you are up next.
Old 08-21-2009, 11:38 PM   #15
Stitch
can you measure where it mounted between the frame rails and tell me where you measured at and I'll take measurements also...that'll solve the dilemma ...thanks
or on second thought, you could just measure the bar and show me a picture where it mounts...then I can see if it'll work...thanks man
Old 08-22-2009, 12:09 AM   #16
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
"Anything will work if ya let it"-Travis W. Redfish, Roadie 1980
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 08-22-2009, 09:27 AM   #17
Gene
Gene's Avatar
34 inches wide where the brackets mount to the frame.
Old 08-22-2009, 12:14 PM   #18
Gene
Gene's Avatar
thanks...Chuck.
Chuck shipping to 29151 is 32.36, so total is 82.36
Old 08-23-2009, 09:19 AM   #19
Stitch
let me measure my truck and we'll see what it is...thanks
Chuck.
Old 08-23-2009, 03:52 PM   #20
Stitch
scratch that idea...I don't think it'll fit on a 1/2ton swb frame...
Old 08-23-2009, 08:25 PM   #21
f.monroe
f.monroe's Avatar
Looks like I am interested . Shipping to a business address in Bryan, Tx 77808 please .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 08-23-2009, 08:53 PM   #22
Gene
Gene's Avatar
Looks like shipping to 77808 is 18.83
so 68.83 total Fedex Ground
Waiting to hear back from Jmac11 pm sent
Old 08-23-2009, 10:21 PM   #23
Stitch
Frank
are you putting this on a 1/2 ton frame? if so, I wish I knew how...also that I probably passed up a smokin deal...
Old 08-24-2009, 04:53 PM   #24
Gene
Gene's Avatar
This setup came off a 1/2 ton 4wd truck w/ a 10 bolt. I assumed you couldnt use it because your truck is a 2wd?
Old 08-24-2009, 08:55 PM   #25
USSkoval
It should work just fine on a 2wd, the frames are the same at the rear. BUT, the spring hangers are a different height between 4wd and 2wd, so the end links may need changed to a slightly different length. Not sure if it would work on a lowered truck though.
USSkoval is offline   Reply With Quote
