Senior Moment
![]() Join Date: Mar 2002
I just bought this tilt out of a 72. I'm putting it in my 70. My ? is the indacator looks differant and I dont know what a 72 looks like, does this look right? Also there is a grey wire that I understand is the indacator light, my 70 has the fiber optic that comes from the dash, which one do I use, grey wire of fiber optic?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Senior Moment
Pic 2
Senior Moment
pic 3
"Ochre Ogre"
Hook up the gray wire and use that. The fiber optic is for a reg column only. Your indicator is correct for a tilt. You are just missing the white plastic "pointer". I understand that the pointer has recently been made obsolete by GM. Somebody here probably has a stash and they will sell you one. Although I don't know if it is worth doing. They always seem to break just from the act of shifting. Not one of their better ideas.....
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Progress = 0%
I put the same tilt in my '67. You can hook up the grey wire to you instrument lamp circuit. F.Y.I. - The light bulb is located underneath the indicator housing. The fiber optic won't work with that column.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Senior Moment
Thanks Guys. How hard are these to take apart so I can paint it?
Senior Moment
Looking for tips on how to take this apart for painting?
I would recommend that you get the assembly instructions as the tilts can be time consuming and difficult. Working on a tilt column is very difficult and requires a lot of patience. If you have never had one apart, I would suggest getting help on it.
I start by removing the levers, indicator, indicator light,(green shade, shield, and bulb), and flasher button. The round metal cover can be removed using a screw driver and tapping on the base to drive it off. Take care not to damage it as it is just pressed on. Then I remove the turn signal wiring cover and turn signal with the wiring. Next, I remove the tilt spring and trunions. Once the trunions are out, the steering shaft is removed by pulling it out while releasing the tilt, (screw the tilt lever back in for this step). Youwill want to make sure the bottom flange has been removed prior to sliding out the shaft. I remove the lower bearing retainer clip, and bearing housing with the bearing. Next, I remove the upper shift tube die cast retainer which is held on with (4) 5/16'" headed screws. This exposes the shift tube and I remove the clip and washer. At this point the shift tube can be removed by driving it out of the shift bezel. I recommend a good fitting tool for this,as it is easy to damage the upper part of the shift column. Once the column is clear of the shift collar it can be removed as well as the shift collar. Reassembly is extremely difficult and I don't believe that I can describe it with words. Reassembly is not simply"reverse the above instructions". I have rebuilt dozens and they don"t seem to get easier. Jim |
![]() Join Date: Oct 2002
tilt
I'll 2nd that .If you've never taken one apart it can be very time consuming.
its all about the +6 inches
And they were all black in these trucks, regardless if the rest of the int color.
As for your fiber optic cable, they are not made in reproduction...if you don't mess it up, you can sell it fairly quickly. |
i just bought a pointer for my tilt from ricks truck parts for 10 bucks. or if your lucky you can find on in a wrecking yard out of an old chevy van good luck!
