08-20-2009, 12:24 AM | #1 |
Trying to figure out my loping problem
I posted this in another thread and have had no action on it. So I'm re posting it by it's self. The bracket that contains the map sensor also contains the EST module and another device that has a tube from the EGR and a tube from the back side of the TBI unit. It has an adjuster screw inside of an air filter. What is this part?? I think I figured this one out. Is it the EGR solenoid? I have had a lopeing problem with this truck since I've had it. The emissions control stuff has been removed by the PO. Replaced several different items, The IAC valve, o2 sensor, knock sensor, ESC sensor, fuel pump relay, thermostat, ignition control module, ignition coil, MAP sensor and generator, cap and rotor. The EGR valve holds vacume and it has new, correctly gapped plugs. All the vacuum/coolant hoses have been replaced in the last year. I also replaced the one way check valve on the drivers side of the engine. Then I happened to unplug the MAP sensor and Viola, the lopeing problem vanished. With the Map sensor plugged in it barely wants run. The ECM has always had a code 44(lean exhaust) I have been able to eliminate other codes by replacing the parts that I stated above. Now I have a fuel pressure tester that I plan on hooking up this weekend to test out the fuel pump. Am I doing any harm to the system, running it with out the MAP sensor plugged in? I get a strong sulfur smell as it gets driven. I don't have any computer stuff for it, Just a paper clip and a Haynes manual. Wish that I could afford all that technology but that will have to wait for now. So what do you guys think Thanks in advance, nativebroncofan
1987 Chevy ck/20 350 5.7 liter with TBI. |
08-20-2009, 07:39 AM | #2 |
dang its hot
Re: Trying to figure outmy lopeing problem
see if you have vacuum at the EGR valve at idle. this can cause these conditions...start there. when you unplug the MAP sensor the computer goes into "fail safe", a rich fuel map to save the engine and to get you home. an energized EGR valve at idle will mimick a vacuum because that is what it is, a vacuum leak into the exhaust system. this leak beyond what the computer can compensate for at idle. Just a place I would start first
08-20-2009, 09:17 AM | #3 |
Next project: 1970 K10
Along with that, see if the EGR valve might be stuck, or sticking. It may be stuck open just slightly. Use a small pry bar or screw driver and see if it moves freely. Maybe even take it off to see if there is a piece of junk holding it open just a little.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-25-2009, 01:09 AM | #4 | |
glock35ipsc I have taken the EGR valve off and cleaned it and had it tested. It holds vacuum when applied to it. When I cleaned it I used diesel and let it soak overnight. It was a suggestion from someone. I just soaked the bottom half not the hole thing. It moved freely up and down and was cleaned to the Haynes manual specs. So what's the next suggested step? New EGR valve or EGR solenoid. Thanks for your help guys, nativebroncofan
