08-20-2009, 12:56 AM | #1 |
69 K20
Firewall holes, what are they for?
I have seen some posts with pictures of a firewall and detailed info of what each hole is for. Does anyone have this pic or know who might have it?
Thanks! |
08-20-2009, 01:44 AM | #2 |
"THE GREEN GOBLIN"
Re: Firewall holes, what are they for?
Here's one that's helped me in the past it's from one of the replies I got here on the board from another Thread, Hope it helps ..
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
08-20-2009, 01:53 AM | #3 |
69 K20
Thats one of them, thanks.
I do have a question though. On my cabs, there is another hole under the speedo hole and my fuseblock cut-out is positioned a little to the right, closer to where the e-brake cable would come through. I have a 67 cab and a 68 cab. What would the hole under the speedo hole be, and will I have any trouble when I put a 69-72 e-brake set-up in? Has anyone done this? Will I have to move the fuseblock??? Last edited by danw210; 08-20-2009 at 02:14 AM. |
08-20-2009, 02:09 AM | #4 |
69 K20
Here is what I am talking about.
08-20-2009, 05:07 AM | #5 |
"THE GREEN GOBLIN"
WOW your right I have no Idea what would go there. I know someone will chime in soon and help out..
Petey-pablo
08-20-2009, 08:50 AM | #6 |
69 K20
I'm thinking that the second hole {under the speedo hole) might be for an e-brake cable for a 67-68.....anyone?????
08-20-2009, 09:29 AM | #7 |
Fuse Block & Speedo...??
Note: A lot of PO drilled extra holes for stuff!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 08-20-2009 at 09:30 AM. |
08-20-2009, 09:31 AM | #8 |
I don't know - mine has the extra hole too - I'm running my amp hot lead through it though, so I'm kinda glad it's there.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-20-2009, 09:50 AM | #9 |
69 K20
08-20-2009, 12:18 PM | #10 |
Restoration Virgin!
I put a delete plug in mine.....and here's where the ebrake cable goes!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 08-20-2009 at 12:24 PM. |
08-20-2009, 12:44 PM | #11 |
Never Ending Projects
Not sure if this pic helps but this is my '68 right after I removed the front clip.
Speedo cable in the lower hole, plug in the upper. Fuse block in the big square hole. Round hole above the square one is the brake warning light. Rectangle hole below steering column is the e-brake cable. Hope it helps.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-20-2009, 01:15 PM | #12 |
69 K20
Thanks Chevy_Mike, that does help.
08-20-2009, 03:20 PM | #13 |
That is the same set up on my 68. Fused wire coming out of the top hole plug (haven't traced it down yet) and Speedo cable in the bottom hole.
08-24-2009, 05:17 PM | #14 |
It's been a few years since i disassembled mine, but i'm sure that the lower is the speedo cable and the upper is the manual choke cable. Thats how mine was arranged on my '68. Hope this helps !
Chris click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
08-24-2009, 05:39 PM | #15 |
I looked at mine again. I was wrong. I only have a plug in the top hole and speedo cable in the bottom.
08-31-2009, 09:48 PM | #16 |
Where does the tach harness come through firewall or could that be it?
