Old 08-20-2009, 10:52 AM   #1
67cheby
67cheby
67cheby's Avatar
wtb used dropmember or pancaked crossmember
let me know what you have
67cheby is offline   Reply With Quote
Old 08-20-2009, 02:03 PM   #2
SCOTI
SCOTI's Avatar
Re: wtb used dropmember or pancaked crossmember
I have a 73-87 style c.member that's notched 1 3/8". I made some 1/4" shim plates for it (c.member & motor mount stands) to put the total notch @ a lesser amount (1 1/8").
It's a pkg including c.member w/hardware, 68 steering box w/linkage & the shim plates. You'll need to buy some POL tubular motor mount stands as that's what I used & that's what the shim plates were for.
This was bolted into my 68 & the steering would go lock to lock w/approx 1/8" clearance. I'd take $350 (you pick it up).
I also have an older version PB Dropmember (V1) powder-coated satin black & set-up for sbc. It's was installed in the same 68 as the notched c.member. Includes c.member, sbc motor mount hardware & stands, & surface rusted installation hardware. I'd take 1K for it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-20-2009, 02:31 PM   #3
67cheby
67cheby
67cheby's Avatar
do you have pics
Old 08-20-2009, 04:25 PM   #4
SCOTI
SCOTI's Avatar
Unfinished @ this point in the pics but I was mocking everything before final welding took place. It's Krylon satin black now (professionally applied of course ). You can also see the MM towers that are not included (they were already painted satin blk).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
