Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-20-2009, 05:43 PM   #1
tx512
I need help on choosing a stall converter?!.
I need help on choosing a stall for my truck. I am not sure that i fully understand exactly how they work.
i am building a 350 (.30 over), dished pistons, with vortec heads, air gap intake, long tubes, and comp 268 cam. I have a 12 bolt rear sitting under my parts truck and a 10 bolt on my truck now. Right now I am running 31" bfg all terrains but will be going to street tires once these wear down if I dont sell them first.
Anyhow my question is, is a 2800 stall a good choice or what would you guys recommend? I have a guy that wants to trade me the 2800 for something.
Thanks in advance!!!
tx512 is offline   Reply With Quote
Old 08-20-2009, 05:46 PM   #2
tx512
Re: I need help on choosing a stall converter?!.
Its going in a 81 swb
Old 08-20-2009, 07:18 PM   #3
cobb
cobb's Avatar
What are your plans for the truck? Wanting to race, street, or off road? Might help some people answer you better
cobb is offline   Reply With Quote
Old 08-20-2009, 07:50 PM   #4
AirMale
AirMale's Avatar
call ATI and give them all the specs:
h.p.
cam
trans.
gear
rear tire size
purpose
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 08-20-2009, 08:53 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
agreed, the convertor companies will work hard to help you select a convertor for your specific combination. It's kind of not fair to use their expertise and work then go to a shelf stock convertor from Jeggs or Slummit. But. we all have to work to estimate / bid projects that we may or may not get.
All that aside,, I would suggest you stay away from the used convertor unless you know FOR A FACT that the trans it was in is a perfectly working trans. If the trans went away it filled the convertor with trach,, that you do NOT want in your trans.
OK, a from the hip,, a 268H cam is a pretty mild cam. Sounds like your going to have fairly low compression, a 2800 convertor ought to give you 1800-2000 foor brake stall on the street. It will be a help to get the heavy truck moving,, assuming traction holds. So yes,, a 2500-2800 convertor appears to be a reasonable choice. Be SURE and add a external trans oil cooler also, The stock in-radiator cooler is simply NOT enough for the street and much stall at all. Besides, a trans oil cooler is cheap, and great insurance for any trans.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-20-2009, 09:03 PM   #6
tx512
this will be a street truck probably no strip.
Old 08-20-2009, 11:52 PM   #7
Rodms
Rodms's Avatar
tx if I were you ,not hurting any feelings hopefully,I would call Kenny at PTC and tell him your build an he will build for you,just my opinion.Good luck!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-31-2009, 06:45 PM   #8
shortbed70
shortbed70's Avatar
I have about the same motor but little bigger cam and motor 350 (.060) 361 and I have a 25-2800 and with my 3.73 and 700r4 trans it works really well on the street. From a dead stop and stand on it the rpm's will jump to 2500 and break the tires loose...On the foot brake I can get a little over 2500 before it wants to push through the brakes.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-01-2009, 07:41 PM   #9
5.7L JWL
check out www.converter.com it FULLY EXPLAINS HOW THEY WORK AND HOW TO DETERMINE THE STALL OF YOUR CURRENT CONVERTER in the FAQ section.
Another good site is www.transmissioncenter.net.
Jay
'98 C-1500 ECSB 5.7L Edelbrock shorty headers Ceramic, Stage 8 locking header bolts, Magnaflow S/S y-pipe w/converters, Magnaflow S/S
Cat-Back Exhaust (DI 2.5" / SO 3.5" w/ 4" Tip.) Synthetic Fluids throughout. Polished TB with Blade removed, ASP Pullies, Performance Distributors "Vortec Firepower" Ign. Kit, BlackBearPerformance Tuned PCM '84 Kawasaki KX-80 "Mint"
5.7L JWL is offline   Reply With Quote
