Old 08-20-2009, 06:09 PM   #1
mclairmo
TH400 Kickdown Switch
I am running a Th400 with no kickdown switch. Is this ok? I cannot find any solid info on whether or not I really need it. Some say I need it or I will burn up the trans. Some say it is fine without it. Not racing the trans and not towing. It's used lightly. I know B&M and Lokar make kickdown switches but I am considering using a nitrous full throttle micro switch mounted to the carb to activate the kickdown switch at full throttle but don't want to go through the trouble if I don't really need to do this. Any insight?
mclairmo is offline   Reply With Quote
Old 08-20-2009, 06:16 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: TH400 Kickdown Switch
Not sure if it's necessary or not , but I'm running the Lokar switch. Makes flooring it a lot more fun.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-20-2009, 06:25 PM   #3
bigbadchev72
People know me
bigbadchev72's Avatar
Smile Re: TH400 Kickdown Switch
I dont think that it is neccesary, you can manually do it with the shifter. I used a microswitch with a long lever i got out of johnstone supply for under $10 it is used in vending machines
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 08-20-2009, 11:06 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You don't need it but it also means it won't kick down a gear if you floor it. Last truck I had, the guy put a toggle switch on the dash so he could manually kick it down and let it hold that gear.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-21-2009, 10:13 AM   #5
turp mcspray
turp mcspray's Avatar
You can find a factory switch that mounts on the gas pedal assembly, under the dash on any 3/4 or 1 ton truck through the 70s and 80s. These trucks are about as easy to find as a beer at a high school party! A new GM switch is under $30. I'd just snag a used one for next to nothing and grab the wiring harness at the same time.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-21-2009, 10:40 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My kickdown switch is not connected. When I had my valve body modified, the transmission shop guy, who is an old drag-racer, tested it to see if it was still working, and it was. So, until I install the drivetrain back into the truck, and use the Lokay stuff I have, it won't have one.
But, while I was still driving it, he put the smallest modulator he could get on it, a black one. This allowed the transmission to downshift based on vacuum and while not the same as a full-fledged kickdown, still made it more driveable.
Member Nr. 2770
Old 08-21-2009, 04:29 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i've heard tranny guys say it both ways.
Old 08-21-2009, 04:43 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
I didn't have one on my TH400 in the '69 and it was fine. of course, with a 454/3.73's, it had enough torque that it didn't matter much. If I really wanted to move around, I just pulled it in 2nd and laid the throttle down.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 08-21-2009, 09:46 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Member Nr. 2770
Old 08-22-2009, 12:07 AM   #10
Longhorn Man
after typing that, I wondered if anyone was going to say something.
Old 08-22-2009, 12:27 AM   #11
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
We sure are a mature group of fellows aren't we? haha
mikajo39 is offline   Reply With Quote
Old 08-22-2009, 09:19 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Everytime someone uses the word "tranny" I have to sit on my hands to keep from saying something. This time, I thought it was warranted...
Member Nr. 2770
Old 08-22-2009, 11:05 AM   #13
mikajo39
mikajo39's Avatar
It's ok... I actually do that same thing
Old 08-22-2009, 08:12 PM   #14
mclairmo
I don't like the word "tranny". I use "trans". Is that any better, or it that actually worse?
Old 08-22-2009, 09:46 PM   #15
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Actually, it'll run fine without the switch hooked up. You will get a 3-2 downshift, but you will never get a full-blown 3-1 downshift when you really tromp on it.
I *think* before about 1972, the downshift switch was mounted on the throttle linkage. It was a momentary contact switch activated by the carb lever. In '71 or '72, the switch got moved to the gas pedal.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 08-23-2009, 10:06 AM   #16
Longhorn Man
that is correct. threy moved it to the throttle in 71 whey they went to a cable throttle instead of a throttle rod. The carb mounted switch can be quite hard to find... and harder to find working.
Old 08-23-2009, 12:58 PM   #17
70jnktrk
70jnktrk's Avatar
The kickdown switch is not necessary on the TH 400..mine has been without since the swap...1991...tranny performs perfectly!...
70jnktrk is offline   Reply With Quote
Old 08-23-2009, 05:35 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I had a good 3-2 downshift and unless I was going really slow at no time would it drop into first. Never drove it with a proper electrical hookup to cause the downshift, but it has been checked and is operable. Like I said earlier, using the smalllest possible (physical size) modulator is one way to be able to live w/o the operable kickdown switch.
Member Nr. 2770
Old 08-24-2009, 09:54 AM   #19
turp mcspray
Why not just add the switch? It's not like it's something expensive or difficult to do. Just curious.
Turp Mcspray
Old 08-24-2009, 04:37 PM   #20
Longhorn Man
if it is a 70 or older, it is expensive and difficult to make it work properly
Old 08-24-2009, 05:01 PM   #21
Sinister
Between Trucks...
Sinister's Avatar
'70 or older on the truck or transmission? On my '69 I just slapped on the Lokar switch ran it to 12 volts and had it working. Not sure how old the transmission is.
Beat it to fit,
Old 08-24-2009, 06:04 PM   #22
mclairmo
I think Longhorn Man was referring to an oem kickdown switch set up mounted on the intake and actuated by the throttle linkage. The Lokar switch mounts to the trans and will work with all Turbo 400s for all years.
Old 08-24-2009, 06:08 PM   #23
Sinister
Between Trucks...
Sinister's Avatar
Doh, gotcha.
Beat it to fit,
Old 08-24-2009, 06:17 PM   #24
turp mcspray
He doesn't have to use the older style. The newer style is easy to find and cheap. It's not like it's a corvette or a mopar, where the "resto" police will get him because it's not original. LOL!
Turp Mcspray
Old 08-24-2009, 07:01 PM   #25
mclairmo
If I do add a kickdown switch, I'm going to use a nitrous full throttle micro switch and mount it to the carb. About $10-$15 and some wire. Cheapest way to do it that I could find other than a toggle switch on the dash.
